Arborwear
Author Topic: Straight 450 clutches  (Read 666 times)
Offline rdobb13
« on: September 30, 2017, 10:02:34 AM »
Any dry clutch guys got a second to help a fella?
Took about two years too long to rebuild the motor in my straight 450.  Put it back in last week and surprise, the clutches stuck.  They have about a year on them.  Sanded them down, checked the tolerances and they are good.  Should I be able to turn the sprocket with a pry bar when the lever is pulled back to release them?
First I thought sure, it's a clutch.  Now I'm thinking no because it's a whole pack.  Weight and engine force might be required.  It worked fine before.
Thanks to any of you guys that offer advice.
Offline Gearbox
Re: Straight 450 clutches
« Reply #1 on: September 30, 2017, 10:28:22 AM »
ram it into a tree gently .Pull both clutches and let the clutch out . Then slip the steering clutches to shine them a bit .
Offline rdobb13
« Reply #2 on: September 30, 2017, 11:32:53 AM »
I've got the one side out, cleaned, and reinstalled but I tried releasing the lever and moving them with a pry bar to see it's free but it still won't turn.
Putting it back together and trying your suggestion is my next step.  Just wanted a second opinion before I do.  Thanks.
Offline coxy
« Reply #3 on: September 30, 2017, 03:10:36 PM »
how do you ram it in a tree gently  ;) :D sorry couldn't  help my self  :)
Offline red
  • we will never forget
« Reply #4 on: September 30, 2017, 08:32:19 PM »
Its clear as MUD
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline snowstorm
« Reply #5 on: October 01, 2017, 07:41:32 AM »
if the bar is 5 ft ya if its 2ft no
Offline rdobb13
« Reply #6 on: October 08, 2017, 05:57:05 PM »
Well, no luck after I put it back together.  It stuck just the same.  I measured the fibers to make sure they weren't swollen but looking at the pressure plate there is no room for it to release.
Deere way didn't work, now it's the hillbilly engineering shot.
Put two washers between the pressure plate and brake drum.....worked like a charm.  Let it slip and shine a minute, took one washer out and life is good now.
clutches
Started by coyotebait on Sawmills and Milling
Last post May 14, 2017, 08:25:24 AM
by thecfarm
Clutches, Clutches, Clutches!
Started by newguy on Sawmills and Milling
Last post January 07, 2005, 02:03:20 PM
by Fla._Deadheader
Linn Clutches?
Started by FloridaMike on Sawmills and Milling
Last post August 06, 2017, 11:26:54 PM
by FloridaMike
Source for Clutches
Started by samdland on Sawmills and Milling
Last post September 11, 2004, 03:19:03 PM
by Tom
