Arborwear
Author Topic: My make do with what you got pump house  (Read 791 times)
Offline Darrel
  • Never throw an unopened log on the burn pile.
« on: October 04, 2017, 11:25:05 PM »
I have some Doug fir 4x8x16' taken from a house last summer, a whole bunch of tree tops and small logs I was too cheap to throw out, a mix of ponderosa pine and juniper.  Plenty of 1" blue pine I sawed last summer. A need to get this thing covered before the snow flies.
I'm leaving it a dirt floor as it is going to be replaced next summer and I'll be moving it onto a foundation with floor.  Will be bolting it together for easy disassembly when the weather warms up next spring.
I live off grid so I pump a 1550 gallon tank full about once a week and use gravity flow to my RV.  The small pump you see in the pic is for fire suppression. I use my Hobart stick welder to power the pump in the well.
Anyhow, here is what I have so far.
m
1992 LT40HD
Offline thecfarm
Re: My make do with what you got pump house
« Reply #1 on: October 05, 2017, 08:31:17 AM »
That wheel barrow helps on on the size of thing. Going to insulate the walls?
Offline Darrel
« Reply #2 on: October 05, 2017, 02:06:08 PM »
It is 12' X 14' and the roof will have a 3/12 pitch. I plan to insulate it with foam.
1992 LT40HD
Offline Darrel
« Reply #3 on: October 13, 2017, 09:21:16 PM »
Well the pump house project got put on hold because my wife wants a mud room next to the RV. So Vera and Grandson Ike helped me cut shiplap on the table saw and we nailed it down to a juniper foundation.  Juniper because even though I'm using concrete pier blocks it is still very close to the ground and pine won't hold up too long.  I will get back to the pump house as soon as I finish the mud room.
1992 LT40HD
Offline Darrel
« Reply #4 on: November 03, 2017, 07:12:38 PM »
Ok, I've made some progress.
Inside looking up.
View from laying on my back on the roof.
Inside 5th wheel looking out.
I leveled one side of the rafters on the mill and sawed a flat on the top side for nailing the sheathing to. Some of the rafters are Pondarosa pine and some are western juniper.
Got plastic on the out the outside of it yesterday and the snow is flying today.
1992 LT40HD
Diesel Primary pump from tank to injector pump
Started by Ironwood on General Board
Last post January 25, 2005, 08:12:11 PM
by Ironwood
Head cold. Make it stop...make it go away!! Man, I turn into a baby...
Started by maestro on Health and Safety
Last post September 16, 2008, 03:56:29 PM
by Riles
question
Heating a hoop house/green house.
Started by pinebugsrus on Firewood and Wood Heating
Last post June 03, 2012, 08:21:44 PM
by pinebugsrus
question
pump
Started by dnsnook on Forestry and Logging
Last post February 16, 2012, 04:24:40 PM
by snowstorm
