Arborwear
Author Topic: stihl oil vent  (Read 671 times)
Offline terizea
stihl oil vent
« on: October 06, 2017, 07:05:21 AM »
chain on my stihl ms390 wasn't getting enough oil, new pump, o-rings ,adjuster all the way, when I put wire in oil vent it was like a release valve ,oil and air came out is this a defective valve? after cleaning I started it up and oil came out a lot where it suppose to after cutting I directed saw toward plywood so I can see if oiling but no oil against plywood
Offline Woodcutter_Mo
Re: stihl oil vent
« Reply #1 on: October 06, 2017, 04:24:23 PM »
 Have you inspected the bar to make sure the oil inlet hole is not plugged? I've had wood chips plug the inlet a few times.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball bale/dump bed, '07 Honda Rancher
Offline joe_indi
  • The older I get the more I learn
Re: stihl oil vent
« Reply #2 on: October 08, 2017, 11:07:42 AM »
......when I put wire in oil vent it was like a release valve ,oil and air came out is this a defective valve? after cleaning I started it up and oil came out a lot ..
That is not a good sign. The oil tank needs that vent to let in air  to reduce the vacuum (low pressure) formed by the oil being pumped out.
But you have pressure. Which mean the pump is not pumping out onto the guidebar but pumping in air into the tank. This usually happens from a worn out pump.
But a temporary fix, if it works, is to use a more viscous oil.
Offline knuckledragger
Re: stihl oil vent
« Reply #3 on: November 06, 2017, 02:36:24 AM »
Take the plastic vent plug out, throw it in the trash. Facing the muffler look to the lower left corner. You should see it there. Sometimes compressed air is necessary to remove it. After you have removed the plastic plug replace it with a 6mm machine threaded screw. The oiler vent should allow correct pressure then.
Offline Texas-Jim
Re: stihl oil vent
« Reply #4 on: November 06, 2017, 07:30:30 PM »
That plastic plug isnt a vent on most saws, its just a plug where they drilled a hole. If you take out that plug and turn saw over oil will leak out. The vent is little silver plug by the oil outlet. You can use a needle or something to move it in and out, maybe some carb cleaner.
What we do in life echoes through eternity.
Stihl 029 Bar Oil Vent
Started by luvmexfood on Chainsaws
Last post July 13, 2014, 01:54:12 AM
by luvmexfood
Stihl 028 Gas Tank Vent
Started by Ohio_Bill on Chainsaws
Last post January 05, 2008, 07:59:57 AM
by Ohio_Bill
Stihl 039 Gas tank vent
Started by rank on Chainsaws
Last post February 02, 2018, 07:28:31 PM
by moodnacreek
moved
MOVED: Stihl 028 Gas Tank Vent
Started by Tom on Sawmills and Milling
Last post January 04, 2008, 08:29:23 PM
by Tom
