KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: 12x16 TF on treated deck frame?  (Read 454 times)
Offline JustPlaneBen
« on: October 07, 2017, 09:25:48 AM »
Hi folks,
I'm new to the forum and new to timber framing. I'm in the process of building a small shed/cabin in the woods. It's primarily going to be a storage shed, but I'm going to insulate it and put in a small wood stove so that it can be used as a workshop or living space. I am a builder by trade, and have some left over materials that I can use to help keep the cost down. Anyway... I decided on a 12x16 size, and set 6 concrete block piers last weekend. I have the material to do a 2x8 pressure treated deck frame, and I have rigid foam to insulate the floor. I have a couple sheets of advantech, and was going to buy a few more, and that would be the floor system. I was then planning to just build a simple stud frame with rough sawn lumber, sheath, and insulate with rigid foam. But... I think it would be a lot more fun to build a timber frame, something I don't have much experience with. It seems that the 12x16 Garden shed from Jack Sobon's book is a popular choice, and it would fit on the piers I'e already set.
So... down to my question. Being that I have the lumber to build a floor, and it will be a lot cheaper than purchasing the floor timbers from a saw mill, would it be reasonable to build a 12x16 timber frame on a PT 2x8 and advantech deck frame? In thinking it over, it seems fine to me. The 6 posts would basically sit directly above the 6 concrete block piers that I have already set. My only concern is how to attach the posts to the frame. I was thinking of doing a mortise of sorts on the bottom of each post, so that they would have a small shelf that would rest on the corner of the deck frame, and then extend 8" down so they could be through bolted to the 2x8...
I still need to get a price on timbers from a local saw mill before I commit to doing this rather than a stud frame, but I think it would be fun. Also, I live in upstate NY, so we do have snow. The floor frame is a 10" off the ground at it's lowest point (ground is not level). If anyone has any thoughts on this I'd love to hear 'em!
Ben
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: 12x16 on treated deck frame?
« Reply #1 on: October 07, 2017, 09:44:21 AM »
I don't have any of the info you are looking for but I have thought about the same thing. So, welcome to the forum, I am now along for the ride. Wherabouts in Upstate ny?
I knew what I thought I meant.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: 12x16 TF on treated deck frame?
« Reply #2 on: October 07, 2017, 10:33:24 AM »
You can create mortises in the 2x floor framing to accept stub tenons on the bottoms of the posts. Simpson makes a variety of straps and nailer plates that you can run down the outside of the post to the sill boards and cover with siding.
I am raising a 12x16 Sobon shed at Old Austerlitz tomorrow, for the Austerlitz, NY historical society's fall festival.
« Reply #3 on: October 07, 2017, 09:34:25 PM »
Thanks for the input. Using simpson hardware is a good idea. I was thinking of just carriage bolting it, but a nailer plate could do a nice job of tying it together. I'm up in the Adirondacks, a couple hours from Austerlitz, but I'm tempted to run down there tomorrow to observe the process.
    • My homepage
« Reply #4 on: October 08, 2017, 06:45:38 PM »
It was nice meeting you, and thanks for all the help. I'll be doing it again next year.
With a bunch of help, some volunteers, and some people roped in from the audience, we raised a 12x16 shed frame today.
A friend of mine nailing up a pine bough:
Using Treated Pine Posts as Timber Frame for farming shelter?
Started by wkheathjr on Timber Framing/Log construction
Last post October 28, 2009, 11:07:41 PM
by Ernie
Time to re deck the deck
Started by rimshot on Sawmills and Milling
Last post October 01, 2013, 06:43:41 PM
by rimshot
Treated ends vs 104
Started by westyswoods on Ask The Forester
Last post February 11, 2012, 10:45:46 PM
by Ron Scott
smiley
CCA treated timber
Started by EC on Forestry and Logging
Last post January 19, 2002, 02:31:49 PM
by Don P
