Arborwear
Author Topic: Black locust fence posts  (Read 2577 times)
Offline PA_Walnut
Re: Black locust fence posts
« Reply #20 on: December 23, 2017, 04:11:21 AM »
Great! I have some 4x4's ready to stick into the ground. Don't have much into it, so will just wing it!
Thanks.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline armechanic
« Reply #21 on: December 23, 2017, 11:07:18 AM »
I wouldn't put them in the ground green,  They need to season awhile.  The only problem with locust fence post is, it will tend to split as it ages, it is hard to keep staples in.  You need to go around and whack them tight.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #22 on: December 24, 2017, 04:41:37 PM »
We always cut and stacked our post for a year before using, criss-cross ten to the row and ten rows high.  The "old folks" only used seasoned post and never put any post in the ground that had bark on it.  If they "had" to use a green post, it was debarked to above ground level.
My Brother and I would fell next year's trees this year and let them lay.  We would then take the 5' crosscut saw and buck the felled (year old) trees, tote the post out, and then fell the trees for the next year.  Grandpa would sharpen and set the crosscut saw before we began sawing.  We never had a power saw.  This was our Winter job and we were paid 5 cents per stacked post.
Offline Timbercreekfarm
« Reply #23 on: February 18, 2018, 09:41:12 AM »
In central ny an 8' post 6" diameter is $5
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #24 on: February 18, 2018, 12:28:28 PM »
Lots of fellows here  used to sell split and sharpened BL posts 6' long years ago.
Split em with and axe and wedges and sharpened on an old fashioned buzz saw pto driven.
Rarely peeled them.
when they were dry pounding staples in was not too much fun.
Lasted for years and years.
State of NY sold BL stumpage on an estimate basis for $.25 per post.
Almost all here now are PT southern yellow pine.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Al_Smith
« Reply #25 on: February 18, 2018, 01:17:43 PM »
The idea of using the inner portion of veneer logs for posts and landscaping timbers certainly changed the way of making fences etc .Added a lot more value than using them to make OSB also.Somebody was thinking in the marketing department .
Black Locust for fence posts??
Started by letemgrow on Forest Education
Last post March 23, 2009, 11:58:14 AM
by letemgrow
Black locust for fence posts and decking
Started by SawyerBrown on Ask The Forester
Last post August 29, 2014, 09:05:27 AM
by Al_Smith
Black locust borers-Fence posts
Started by Faron on Forestry and Logging
Last post October 27, 2008, 09:53:24 PM
by Faron
Black Locust Fence Posts in Central Virginia
Started by jameythompson on Sawmills and Milling
Last post March 29, 2014, 08:34:33 AM
by doghunter
