Arborwear
Author Topic: chain saws were in storage for 14 years  (Read 981 times)
Offline xenduro
« on: October 12, 2017, 01:16:54 PM »
where do I start trying to get them running again
tanks were empty    and ran some stabil thru them   in 2003
 tks greg (67 year old)
all I know is that  I do not use e85 in them
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: chain saws were in storage for 14 years
« Reply #1 on: October 12, 2017, 01:32:53 PM »
 Welcome to the forum Greg.
I'd squirt a little 30 wt in the spark plug hole and pull them over a bunch of times.
then go right ahead and gas them up and see if they will fire up. Unless the gas lines have rotted I bet they will.
What kind of saws are they?
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline xenduro
« Reply #2 on: October 13, 2017, 03:02:57 AM »
that sounds easy tks
sthil's
my great old farmboss 041   (old I guess early mid 80's)
    my up in a tree 021    20-25 years old and my
NEW   044                      about the same age
the 041 gave me trouble once and I got the 044 before my buddy sthil saw dealer  fixed it
we retired in 2003 and took a short 14 year RV trip    starting in NY    ending in Montrose CO
also a old ECHO back pack blower  and a ?red ???? weed wacker to try and get going
i'll check hoses
Offline xenduro
« Reply #3 on: October 17, 2017, 07:42:05 PM »
ok  I did the echo blower first   little starting fluid and oil   in cylinder   right up
the 021    could not reach plug     starting fluid    fancy sthil gas(above also)
right up
Offline sawguy21
« Reply #4 on: October 17, 2017, 08:02:36 PM »
Leave the starting fluid on the shelf and use a squirt of fresh pre-mix. Ether is very hard on crankshaft seals.
Offline thedoublejranch
  • 40+ acre timber farm
    • The Double J Ranch and Timber Farm
« Reply #5 on: November 05, 2017, 12:00:35 PM »
If it does start (run past the initial prime), you will be lucky, usually the carbs are all dried out, full of corrosion from aluminum oxidation and residue left by old fuel that has evaporated away. But you may get lucky. Yes, a nice puff of pre mixed fuel. Let it run at a modest speed while on choke, then choke off, still modest speeds, this will flood the crankcase with the oil needed and the low pressure (vacuum pulse) makes the oil fall from being suspended in the fuel and lubricate the roller and ball bearings. Dont rev it up hard till the cylinder is warmed up which wont take too long.
The Double J Ranch & Timber Farm.
Member "NWOA" National Woodland Owners Association"
Saw Chain Storage . . . .
Started by TexasTimbers on Chainsaws
Last post December 16, 2006, 12:20:20 AM
by TexasTimbers
Chain saws...which one?
Started by Henry-Adams on Sawmills and Milling
Last post July 22, 2004, 08:50:42 AM
by Henry-Adams
New to chain saws?
Started by Kevin on Chainsaws
Last post November 05, 2003, 06:25:42 PM
by Duane_Moore
Own three chain saws if possible.
Started by aquacanis on Chainsaws
Last post April 01, 2018, 03:03:39 PM
by mike_belben
