Arborwear
Author Topic: Damaged Red Pine bark  (Read 386 times)
Offline Nate R
« on: October 13, 2017, 11:13:53 AM »
Greetings! Been lurking for a while, but signed up to post a question finally:
2 years ago, bought 4 acres of nearly 60 year old planted red pine. Had it thinned this year (Basal area from 200 down to 130ish, 315 Trees/Acre down to 175 or so) The cutting was in late June/early July. Last week, I had someone come out w/ an ASV120 and Fecon grinder and grind up a lot of the slash and some stumps.
One of the operators scraped a couple trees with the back of the ASV, one I didnt' notice until later. One of the red pines that was scraped is RIGHT on the border of an area where we want to later build a cabin. I'm guessing an area of bark about 8" x 6" has been removed entirely. What can I do to maximize the potential of keeping this tree alive and healthy? I've read about chiseling the bark smooth/straight around the wound to allow for better healing of the edge, and otherwise, just monitoring the tree from there. Given that this is red pine, and not hardwood, do you still think I should chisel around the wound? Anything else I can or should do? What should I watch for to determine health of a 70 ft red pine? (Hard to see the needles up close!)
Thanks!
-Nate
Offline barbender
Re: Damaged Red Pine bark
« Reply #1 on: October 14, 2017, 01:31:04 AM »
I wouldn't do anything with them. Red pine is quite resilient. I've seen Red pine with extensive fiber damage, 1 or 2 inches deep, that survive just fine. Just a bark scrape will seal over with pitch and won't be a problem.
Offline Ron Scott
« Reply #2 on: October 15, 2017, 09:58:14 PM »
If its just a scrape of the bark and not a deep cut into the cambium (outer wood layer) the tree should be alright. The "shinny wood" will heal over soon.
~Ron
Offline thecfarm
« Reply #3 on: October 16, 2017, 06:26:00 AM »
Nate R,welcome to the forum.
That time of year the bark comes off REAL easy. Hard to work around trees without hitting them.
damaged bark on oak
Started by proteus on Forest Education
Last post May 01, 2013, 11:26:21 AM
by proteus
Mending damaged bark?
Started by scgargoyle on Ask The Forester
Last post March 29, 2013, 07:55:58 AM
by WDH
Best Way To Removing Pine Bark
Started by semologger on General Board
Last post February 07, 2008, 11:18:17 PM
by Sprucegum
Loose pine bark
Started by bandmiller2 on Sawmills and Milling
Last post August 19, 2010, 07:58:08 PM
by bandmiller2
