TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Hickory  (Read 497 times)
Offline xlogger
Hickory
« on: October 14, 2017, 01:16:21 PM »
I've got a guy that wants me to dry some 4/4 hickory for him. It's been air drying about a year and I tested a couple boards around 16%. I've never dried hickory would you treat it just like anything else and turn it up to 120 and set the wb at 75? He also said he might have some oak not sure red or white that was cut at same time he might want to put in kiln with it.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Hickory
« Reply #1 on: October 14, 2017, 07:47:08 PM »
Yes Sir.  That is what I would do.
Offline xlogger
Re: Hickory
« Reply #2 on: October 15, 2017, 06:26:10 AM »
I didn't test the oak, he did not bring a sample over with him. Do you think I could tell him to bring both? Probably not over a couple hundred feet of both.
Offline WDH
Re: Hickory
« Reply #3 on: October 15, 2017, 07:35:37 AM »
If the oak is air dried, should be fine.
Offline GeneWengert-WoodDoc
Re: Hickory
« Reply #4 on: October 15, 2017, 08:26:45 AM »
The temperature you suggest is fine, but the WB is too low. Drying Hardwood Lumber suggests two percent drier than the surface MC, which is likely around 13% MC, so start at 11% EMC.  Then after about 12 hours, go directly into the schedule values, or maybe take an intermediate value and then the schedule.
With hickory, the machining quality really drops if you over-dry the wood, so avoid an EMC under 6.5% EMC.
Mixing oak and hickory at low MC is not an issue.
3 sided husk on hickory nut - what type of hickory is it?
Started by Lanier_Lurker on Tree, Plant and Wood I.D.
Last post August 25, 2007, 09:18:14 AM
by Lanier_Lurker
Red Hickory (Pignut Hickory) value?
Started by jbburd on Sawmills and Milling
Last post July 18, 2007, 08:37:00 PM
by jbburd
What to do with Hickory?
Started by WoodenHead on Sawmills and Milling
Last post January 12, 2014, 11:40:44 PM
by TimRB
Hickory
Started by MTU Husky on Sawmills and Milling
Last post June 16, 2010, 11:40:36 PM
by Tim/South
