KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Used Tire Chains  (Read 760 times)
Offline Coconut
  • Raised on saw dust
Used Tire Chains
« on: October 14, 2017, 04:35:29 PM »
Hi Folks ! Looking to repair some worn out links on my tire chains. Should I use clevis or quick links? Or what?  Thanks.
Offline Oliver05262
Re: Used Tire Chains
« Reply #1 on: October 14, 2017, 08:26:46 PM »
Clevis, by all means, and don't skimp on size. Can get pretty spendy, though. Quick links are too soft, if you're talking about the ones you close up and weld together. Side benefit of clevis is the knob on the pin works as an ice stud--------for a while.
If a tree falls in the forest, and then springs back up again; do the squirrels freak out?
"Abandon hope, all ye who enter here"
Offline 1270d
« Reply #2 on: October 14, 2017, 09:10:56 PM »
And pay the money for better quality clevises.   The better ones we have access to are painted orange.  CM brand maybe?   The cheap ones are silver, maybe zinc played or galvy.   They bend and break and strip etc.
Offline barbender
« Reply #3 on: October 14, 2017, 10:33:40 PM »
I'd second the last two comments👍
Offline Maine372
« Reply #4 on: October 15, 2017, 03:53:22 PM »
and take a minute to tighten the bolts on those clevis's every so often. ive seen them rattle loose.
Offline snowstorm
« Reply #5 on: October 15, 2017, 07:55:40 PM »
I used to buy them at a marine supply store.they were under a dollar each. I never had one break
Offline Spartan
« Reply #6 on: October 20, 2017, 01:04:14 PM »
If you have old chain links around that are hardened the best bet is to weld new links in.  Way cheaper and last longer than clevis.  If you do use clevis, tack the back side where the threads show through, then you never have to worry about them loosening.
Used tire chains
Started by barbender on Forestry and Logging
Last post September 26, 2011, 08:49:17 PM
by Ed_K
Tire Chains
Started by ET on General Board
Last post September 08, 2013, 08:47:20 PM
by bandmiller2
Tire chains
Started by Dave Shepard on Forestry and Logging
Last post January 03, 2008, 04:18:14 PM
by Ed_K
Tire chains
Started by Plankton on Forestry and Logging
Last post January 05, 2016, 01:13:42 AM
by Nemologger
