BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Heavy Stuff  (Read 1124 times)
Offline Qweaver
  • The cabin is done and we love it
Heavy Stuff
« on: October 17, 2017, 10:10:39 PM »
When I took this red oak job to saw full 2"x 10" x 20' boards I did not even think about the weight of the boards.  About 170 lbs!  That will test ya!  Got us old guys puffing.  Whee!
Offline bandmiller2
Re: Heavy Stuff
« Reply #1 on: October 18, 2017, 04:48:17 PM »
I hear you mate with those biguns I handle one end at a time until they are on my log deck then the old ASV and forks take over. You must have your own personal union and refuse to lift too much, its not worth it at our age. Frank C.
Offline drobertson
Re: Heavy Stuff
« Reply #2 on: October 18, 2017, 05:47:34 PM »
hear that,, my last job before the spinal fusion was only 16's x2" green pine, those 12" ers got a bit cumbersome,  rollers and  leverage points are critical for sure,, my last 20' oak trailer floor was one like you describe,, I had to pull the  mill out and do one at a time, and for folks that are just beginning, slabs have to be moved too,,and I still miss my mill,
Offline irvi00
Re: Heavy Stuff
« Reply #3 on: October 18, 2017, 07:42:46 PM »
Was there this past Monday. 18 foot red oak in 8/4. My sister helps me off bear, she couldn't budge the 10 or 12 inch planks. Needless to say I hurt all over Tuesday morning.
Offline cwimer973
  • I'm new! Wood-Mizer LT10 - Please Help Me Learn
    • Wimer Hardwoods
Re: Heavy Stuff
« Reply #4 on: October 18, 2017, 07:45:36 PM »
Thats a job where you should advertise free off bearer lessons, TODAY ONLY and see who bites :).  Did a trailer bed the other day at 10 x 2 and realized this requires a different strategy vs. cut off trailer close and final trailer 20 feet away.
Your Fellow Woodworker,
- Chris
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Heavy Stuff
« Reply #5 on: October 18, 2017, 07:52:54 PM »
   I cut a 4" X 20" X 8' mantel and 2 2" slabs off the same walnut log. Just calculated and the 4" one weighed over 250 lbs and 2" ones around 125 lbs. That kind of stuff is way to heavy for me to be lifting up on my long term storage shelves. I use a pulley and my ATV winch for such.
   I agree heartily with earlier comments you don't lift stuff that big. You move one end at a time, slide or roll it or watch your younger helpers. I cut some 2" X 22" X 12' hickory for a guy one time. We slid them on to the forks of his skid steer.
Offline longtime lurker
Re: Heavy Stuff
« Reply #6 on: October 19, 2017, 07:22:09 AM »
Ones that always seem to end up hurting me are "regular" sizes: 6&8 x3's, 10&12 x2's etc etc. Average density of a lot of what we cut is about double white oak so its got some weight in those sizes but it's sorta do-able so you lift first and ache later.
The real big stuff won't hurt you because you don't even try. I gotta do some beams at 15x12x 27' next week. My calcs put them at 2850 lbs each. Only way those can hurt you is if you trip getting off the forklift.
Offline woodman
  • I love cutting lumber on my wood mizer
    • Jim Cripanuk's Portable Saw Mill
Re: Heavy Stuff
« Reply #7 on: November 10, 2017, 09:53:34 PM »
  I put a power feed on my wm e50 works grate
Jim Cripanuk
heavy set
Started by dustyhat on Sawmills and Milling
Last post May 26, 2015, 08:17:47 PM
by hackberry jake
Uh-oh Log too heavy?
Started by Qweaver on Sawmills and Milling
Last post August 10, 2010, 11:27:46 PM
by carykong
Too Heavy ??
Started by Magicman on Sawmills and Milling
Last post December 16, 2017, 01:45:31 PM
by Magicman
Look at these very heavy logs
Started by alsayyed on Forestry and Logging
Last post September 28, 2006, 07:14:58 PM
by maple flats
