Arborwear
Author Topic: Rocks in waiting  (Read 1152 times)
Offline thecfarm
Rocks in waiting
« on: October 19, 2017, 11:30:53 AM »
Yea,rocks in waiting.  :D
First off,the woods road. This wet area has nothing to do with the bog that I posted about a week ago.
This is not really a woods road,but goes to the back field. We use to go across this wet area only a few times a year. Mostly haying season. Tires would get wet going over it. When I had my land logged they used it and made a mess of the wet hole. Yes,they smoothed it over,but the few rocks that held me up was long gone. Could of got by with the wet area,but wanted to fix it.Once and for all.
These are the rocks in waiting. And yes,that is a yard stick.
The reason they are rocks in waiting,too big. I have some rocks all ready there,and with these being 3 feet across,they are a little too big. When I haul in some that are not so big,these in waiting will be put in and be just right.
This is on the end of the rocky road.
This is facing towards the rocks in waiting. You can see them just over the yellow yardstick.
These rocks came from the stonewall that I am moving. Tractor don't really like the rocks that big. It's easier to haul them here instead of way down into the bog.This road is close to the house. Can almost see the house from here.
I will put smaller one between the big ones. This road is getting a layer of dirt. I get dirt from an area that is real close by,so it's handy.
Offline coalsmok
Re: Rocks in waiting
« Reply #1 on: October 19, 2017, 03:44:17 PM »
You may want to invest in a set of feathers and wedges. You could then make your big rocks more manageable. Drill a few holes and tap them tight with a hammer.
Offline thecfarm
« Reply #2 on: October 19, 2017, 06:00:59 PM »
I have been thinking about a drill. I have some I cannot wiggle.
And since you seem to be in the know,what would I need? I have drilled through my cement foundation with some sort of drill and bit that I rented. Same thing?
Offline mike_belben
  • Pulp Friction
« Reply #3 on: October 19, 2017, 08:32:49 PM »
You need a rotary hammer drill and some basic bits to drill the line of holes youll pound the wedges into.
  Hilti is the top dog and they do make cordless.  I have a 36v.  You can just about weld with the battery pack.
Revelation 3:20
Offline thecfarm
« Reply #4 on: October 19, 2017, 09:14:22 PM »
 :o  Guess I better get my sawmill going to buy one. Wonder how much bits are. Another  :o   :)
Offline teakwood
  • Switzerland
« Reply #5 on: October 19, 2017, 09:51:00 PM »
Put those rocks thru a jaw crusher and make nice 4-5" gravel for you roads!! ;D ;D
Offline coxy
« Reply #6 on: October 20, 2017, 06:14:08 AM »
we call them plug and feather wedges here  ;D most that are still in use here are hydraulic no more pounding with hammer  they use them in the blue stone quarrys
Offline coalsmok
« Reply #7 on: October 20, 2017, 06:44:40 AM »
I bought 10 sets a year or so ago for under $100. I just use a cordless drill with a masonry bit and drill a line of holes. If you want to go extreme cordless you could use a star drill and hand sledge to drill them, but that's to much like work for me.
 I have a large rock that needs broke up to move some time sooner than later. I may take some pics when I do. Firewood is at the top of the to do list at the moment though.  I'm way behind this year for some reason.
Offline mike_belben
  • Pulp Friction
« Reply #8 on: October 20, 2017, 10:06:57 AM »
Bits arent bad.. home depot stuff, even harbor freight has em. Its the hilti thatll make you poor for a while.
Revelation 3:20
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #9 on: October 21, 2017, 05:29:17 AM »
Why don't you get a Deere like I did and fix anything you want. Look around you can get one I bet for less than $ 30,000. Makes life easy.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline thecfarm
« Reply #10 on: October 21, 2017, 05:52:17 AM »
How right you are.
But I don't run a sawmill for a living ,so I can't afford a $30,000 toy.  ;D  :D
I have thought about it,than an old junker 10 wheeler,with no tail gate, to haul the rocks away,than a bull dozer to push them into place.
Offline teakwood
  • Switzerland
« Reply #11 on: October 21, 2017, 08:16:53 AM »
I think you can get a excavator way cheaper than 30k
Offline mike_belben
  • Pulp Friction
« Reply #12 on: October 21, 2017, 08:50:55 AM »
Start with the hilti.   :D
Revelation 3:20
Offline Offthebeatenpath
    • OBP Trailworks, LLC
« Reply #13 on: October 21, 2017, 02:35:22 PM »
Ray- I have three electric Hilte rock drills, generators to power them, and more drill bits and feathers and wedges than you'd ever need. If you're serious about splitting some stone, we could try to figure out a time to get together. I'd love to have a tangible reason to check out your farm...
I'm pretty dang busy these days building trails, but when the weather turns I may have a bit of time.
Jed
1985 JD 440D, ASV tracked skid steer w/ winch, Fecon grapple, & various attachments, Hitachi CG-30 tracked dump truck, CanyCom S25 crawler carrier, Volvo EC35C mini-ex, Kubota 018-4 mini-ex, Cormidi 100 self loading tracked dumper, various other little trail building machines and tools...
Offline thecfarm
« Reply #14 on: October 21, 2017, 06:38:49 PM »
Well how about that!! Thank you Jed. Most weeks I have Thursdays and Sundays off. But that is not in stone either.  :D  I suppose your lessons are free?  ;D  I never done anything like that at all. I will feed ya.
    • A&P Saw mill LLC
« Reply #15 on: October 21, 2017, 09:43:51 PM »
How right you are.
I bought it long before the mill thing, for around my land. It just I see them old slow things out there for cheep.
Most want the small ones with a blade. Just think you could take the nice flat stones you come across, the ones the Masons want and put them some where they could get to them Around here I guy can get $200 to 300 a ton. And the best thing you don't have to stick them.  :D :D :D ;)
Sawing since 1987
Offline thecfarm
« Reply #16 on: October 21, 2017, 09:57:15 PM »
That is how we paid for the tractor. Worked it in the woods.Had it paid off quick. Same with a excavator. Would not take long at 2-300 a ton to pay it off. But I don't have many flat ones,just round ones. Of all the 100's that I have dug up,only about 10 have been flat. Most I have kept for some project. Most of them are just about all the tractor wants too.
You also said small. With what I have to dig out,small would not be a good choice.
Offline SwampDonkey
  • Large Tooth
« Reply #17 on: October 22, 2017, 05:14:48 AM »
Can't buy nothing cheap up here, even when it's about worn out. People still think it's worth gold.  ;D ;) You'd have to be real lucky to find a fella selling one in a giving mood. :D
If I was building a road, I would just hire it. I can't afford an expensive piece of equipment as a play toy. ;) I have a tractor with back hoe on it, but it's no heavy excavator. My woods isn't rocky like Ray's. Mostly softball sized and gravelly and occasionally tire size, not truck size. So the tractor can handle all them fine.
Dirty Harry
« Reply #18 on: October 22, 2017, 02:55:09 PM »
A Sunday could likely work for me Ray. And I rarely mind taking my pay in edibles... only thing I'd ask is if we break any drill bits that they get replaced. I could give you a quick lesson and leave the gear at your house for awhile for you to play with if you want.
Jed
Offline thecfarm
« Reply #19 on: October 22, 2017, 06:03:05 PM »
Sounds good.
moved
MOVED: LIFE ON THE ROCKS (or from the rocks?)
Started by Tom on General Board
Last post November 08, 2007, 11:38:35 AM
by Tom
New and waiting
Started by Jake-n-Texas on Sawmills and Milling
Last post March 22, 2015, 07:29:26 AM
by thecfarm
Logs in Waiting
Started by Magicman on Sawmills and Milling
Last post November 14, 2012, 10:15:42 PM
by Tree Feller
Waiting on a call........
Started by Woodhauler on General Board
Last post April 05, 2013, 08:53:52 AM
by WH_Conley
