Author Topic: Timber frame bent/ truss design  (Read 702 times)
Offline dbarron
« on: October 19, 2017, 04:23:08 PM »
I am planning on building a timber frame 16 X 28 porch. It is I値l be attached to an existing stick frame house, off the gable end.  After the frame is completed, I plan on covering the house and the new porch frame with a common metal roof.  The bents will span the 28ft direction. The existing structure has a food pitch of 4.8 , I want to match this pitch with the new frame. The trouble I am having is that if I do drawings to scale, the bents / trusses don稚 look right. All the designers seem to be too crowded, or just not aesthetically appealing to me. Anyone have any advice for designing bents with low pitched roofs? Pictures would be great. Thanks!
Offline dbarron
Re: Timber frame bent/ truss design
« Reply #1 on: October 19, 2017, 04:26:37 PM »
I work third shift, so I am going to catch a few zzzzz, so I may not answer back right away, but I will check back later in the evening. Thanks!
Offline fishfighter
« Reply #2 on: October 19, 2017, 05:29:03 PM »
Your post would get responses in the Timber framing threads. ;D
Offline rl
  • LT 40HDG28 2004
« Reply #3 on: October 19, 2017, 05:38:48 PM »
what are bents....been a builder all my life but never heard that term
rl
Offline dbarron
« Reply #4 on: October 19, 2017, 06:54:59 PM »
Oops, sorry I will repost my question on the timber framing board.
Offline Brian_Weekley
  • I am Batman!
« Reply #5 on: October 19, 2017, 07:02:33 PM »
Traditional timber frames are typically built as frame cross sections called "bents" and independently raised.  This is an example of raising a bent:
e aho laula
Offline Don P
    • Calculator Index
« Reply #6 on: October 19, 2017, 09:31:36 PM »
Try lowering the tie and then to lower the spreading thrust bring the posts way in to give a very generous "overhang", moving towards balancing much of the rafters load over the posts
Edit: this is along the lines of what I've been thinking;
Offline dbarron
« Reply #7 on: October 21, 2017, 09:23:12 PM »
Good Idea, I may play around with similar designs. Thanks for the advice!
moved
MOVED: Timber frame bent/ truss design
Started by chet on Sawmills and Milling
Last post October 19, 2017, 05:37:28 PM
by chet
question
How do I build the Arch in my Timber Frame Truss?
Started by Yellow Barn on Timber Framing/Log construction
Last post December 28, 2012, 10:16:28 PM
by jueston
Timber size calculator and timber frame design.
Started by Joe Vachon on Timber Framing/Log construction
Last post July 07, 2017, 10:25:46 PM
by Roger Nair
Jim's Timber Frame Design Services
Started by Jim_Rogers on Services
Last post December 12, 2017, 06:33:28 PM
by AarMit
