Arborwear
Author Topic: counterweight for cordwood saw  (Read 629 times)
Offline penfrydd
« on: October 20, 2017, 07:57:27 PM »
I picked up a older, used cordwood saw today.  3 point hitch.  PTO shaft powered.  I've been doing firewood for over 40 years, but never had one of these saws.  I hooked it up and it cut fine, but it seems to me that it should have some sort of counterweight on the end of the shaft opposite the blade.  Obviously, it would have to be of a fairly small diameter so that it doesn't interfere with the incoming wood.
Should there be a counterweight or not?
Offline hedgerow
Re: counterweight for cordwood saw
« Reply #1 on: October 20, 2017, 09:20:30 PM »
Some of the cord wood saws had a flywheel but most didn't. I have had several three point PTO driven and none had a flywheel. The one I use currently use I made  it runs a 13 HP gas engine and I don't run a flywheel on it and it cuts fine.
Offline 47sawdust
« Reply #2 on: October 21, 2017, 08:22:56 AM »
A google search of cordwood saws shows hardly any with a flywheel.Mine is pto driven by the tractor and I think the tractor pto system is flywheel enough.
Mick
Offline North River Energy
« Reply #3 on: October 21, 2017, 03:32:21 PM »
I think the flywheel is a holdover from the flat belt drive era. Those were run loose, and the flywheel would 'carry' the blade through the slippage.
I've a LaFont buzzsaw powered by a 16hp motor, no additional flywheel, works well.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #4 on: October 22, 2017, 09:38:09 AM »
That and it wasn't uncommon to run them off of hit and miss engines which are often <5HP.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #5 on: October 23, 2017, 11:32:41 AM »
Flywheels also smooth out the impulses from single cylinder engines especially the hit and miss variety.
Counterweight on LT28
Started by mjeselskis on Sawmills and Milling
Last post August 27, 2011, 08:26:59 PM
by mjeselskis
Cordwood saw rig
Started by DeerMeadowFarm on Firewood and Wood Heating
Last post June 23, 2015, 08:33:17 AM
by DeerMeadowFarm
Cordwood Sauna
Started by Timber_Framer on Timber Framing/Log construction
Last post April 03, 2005, 01:09:12 PM
by KILROY
Cordwood Buildings
Started by Deadwood on Timber Framing/Log construction
Last post November 22, 2007, 01:10:20 AM
by jon12345
