Author Topic: Need 2x4 extension for slab holder  (Read 1986 times)
Offline Brad_bb
    • My timberframe blog
« on: October 20, 2017, 10:06:16 PM »
So I was thinking of building a slab holder to cut my slabs into firewood with the chainsaw.  So yesterday I was going by my elderly neighbors farm and he had been cleaning out his barn and set these folding "saw horses" out by the road for anyone to take.  Naturally I saw them as my potential slab holders.  They are well built from high grade SYP 2x4's and fold up via pivot bolts in the middle.
***The problem is...the 2x4's that stick up above the pivot point need to be about a foot longer to hold at least 4-6 slabs.  My though it to merely add slip-on extensions to those 2x4's.  I'm thinking a metal rectangular sleeve about 9 inches long.  A 12 inch piece of 2x4 will slip half way in the sleeve and get screwed in place, and that unit will just slip over the end of the saw horse 2x4.  It doesn't need to screw on.  By having 6 extensions for each sawhorse that just slip on and off, I don't have to change the saw horse at all and it will still fold up like it does now.
***So is there metal tubing that is made to slip over a 2x4  (1.5x3.5 inside dimensions), either steel or aluminum, or a formed sheetmetal seamless tube like the red pic shown below?
Offline ljohnsaw
Re: Need 2x4 extension for slab holder
« Reply #1 on: October 20, 2017, 10:39:50 PM »
That sounds too complicated and expensive.  What about scabbing a section of 1x4 on the "outside" face of each joint so that it does not interfere with folding.  A couple of lag bolts each and your done.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 54' - using it all to build a timber frame cabin.
Offline Gary_C
  • Sunrise on the Prairie
« Reply #2 on: October 21, 2017, 12:38:16 AM »
Not that I know of. You could always get 2x4 steel rectangular tubing with 3/16 or 1/4 inch wall but either is heavy 6.88-8.9 lbs per foot and expensive.
Better idea would be to close them up and redrill the pivot to about the center of the length and let it open further. But if you do that, you should use light chain or cable to limit the opening as the 2x4's used now probably will not stand up to the additional stress.
Offline Brad_bb
« Reply #3 on: October 21, 2017, 01:30:03 AM »
I thought about changing the pivot point, but that would lower the slabs too much.  The height now is just perfect for chainsawing without bending.  If I permanently scab pieces on to the existing 2x4s, then it will be too long to fold up and fit neatly in thed of the truck on the floor.  I'm pretty sure the best solution is a removable/slip-on extension is the way to go in this case.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: October 21, 2017, 05:48:43 AM »
Steel studs.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Savannahdan
  • Retired.
« Reply #5 on: October 21, 2017, 06:53:38 AM »
You could use some 2X4 extensions that attach with bolts, lock washers and wingnuts.  When finished you could flip them to the down position for storage and transporting. You only need to do the outside 2x4s.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline Brad_bb
« Reply #6 on: October 21, 2017, 07:39:13 AM »
Steel studs will slip over a 2x4?
Offline Don P
    • Calculator Index
« Reply #7 on: October 21, 2017, 09:06:43 AM »
There's a few in the barn, I'll check today.
Another thought, can you attach the extension in such a way that it can pivot upright for use and swing down for transport?
Offline bigred1951
  • logging and sawmilling
« Reply #8 on: October 21, 2017, 11:01:40 AM »
Why not just turn it upside down and put a 2x4 across what is the top now. So when you turn it wont be a saw horse anymore or fold up and it wont tip over.
Offline Brad_bb
« Reply #9 on: October 21, 2017, 02:06:04 PM »
 Thanks Don! Ill have to think about the pivoting thing. It might get too complicated to try to keep them out of the way for transport.
Bigred1951, I dont want to flip them upside down, I think they would be too top-heavy with the slabs with the smaller bottom and more likely to tip over. Ive studied it, and really I just need another 12 to 15 inches on the end of those 2x4's.
    • A&P Saw mill LLC
« Reply #10 on: October 21, 2017, 03:27:28 PM »
Last time I looked yes, But you might have to belt sand the wood on the 2x4s down some.
Sawing since 1987
Offline bigred1951
« Reply #11 on: October 21, 2017, 05:22:40 PM »
I meant add a 2x4 across for stability so it couldnt tip over. Kind of like a table bottom
Offline Don P
    • Calculator Index
« Reply #12 on: October 21, 2017, 06:42:26 PM »
The steel studs I have measure 3.5" ID x 1.25" as opposed to 1.5" for a wood stud. there is about a 1/8"  turned in edge on the outer edges of the C, so you'd need a groove up the sides on one face. I'm no expert on steel studs, there may be other styles. I don't think this one would hold up to the kind of banging I would do while loading. It wouldn't take too much to do a little cutting and weld a tube out of the stuff though.
Offline Brad_bb
« Reply #13 on: October 22, 2017, 10:17:04 AM »
I've never used steel studs but I think they are kind of thin gauge?  For my sleeves I think I would need 16 gauge minimum (0.060) and 12 gauge maximum (.120).
Offline Brad_bb
« Reply #14 on: October 22, 2017, 01:49:05 PM »
I'm going to go check out this deck rail material at Menards and see how strong it is.  If thick enough, it might be strong enough.
Offline Don P
    • Calculator Index
« Reply #15 on: October 23, 2017, 07:44:37 AM »
Yeah, I'd guess the studs are more like 20-30 thou thick. The track, top and bottom plate, is a bit heavier but still not much. It is 3-5/8" id bottom and 1" straight sides.
Look at those sleeves with a cold morning and banging slabs in mind, are they going to be brittle?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #16 on: October 23, 2017, 07:48:51 AM »
I would slide a piece of schedule 40 PVC pipe over the 2x4's.
Offline gspren
« Reply #17 on: October 23, 2017, 09:17:41 AM »
 Check onlinemetals.com and search rectangular aluminum tubing. 2"x4" with a 1/4" wall.
Offline Brad_bb
« Reply #18 on: October 23, 2017, 09:30:09 PM »
Thanks for looking Don P.
WDH and gspren great suggestions.  The aluminum is a bit pricey, but if the deck sleeve and PVC don't workout, I'd consider investing  in it to do it right.
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #19 on: October 24, 2017, 11:25:34 AM »
How about some "boxed" extensions out of 3/4 plywood glued and screwed.  You could slip them on or off as needed.
Wudman
Dog Bowl Holder
Started by lowpolyjoe on General Woodworking
Last post January 15, 2016, 10:49:03 AM
by lowpolyjoe
3 ring pot holder
Started by grouch on General Board
Last post July 30, 2017, 11:57:14 PM
by grouch
planter holder
Started by Dave H. on General Woodworking
Last post September 18, 2016, 03:46:10 PM
by Savannahdan
Firewood holder
Started by marine5068 on Firewood and Wood Heating
Last post July 28, 2015, 07:41:10 AM
by Theo
