Author Topic: HELP - - land survey equipment  (Read 1012 times)
Offline DDW_OR
« on: October 22, 2017, 02:45:39 PM »
I have three tax lots that total 166 acres of hilly/wooded that i need to put a fence around and cross fencing
I work alone and am trying to find a good robotic total station kit
what will i need for under $3,000
i know i will need an accuracy of 3 degree or less
I have two survey tripods, nothing else.
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Texas Ranger
  • Texan, by God and by choice.
Re: HELP - - land survey equipment
« Reply #1 on: October 22, 2017, 03:40:26 PM »
Check Forestry Suppliers or Men Meadows on line.
Offline DDW_OR
« Reply #2 on: October 22, 2017, 07:14:14 PM »
I could not find "men meadows", but i did find benmeadows.com
did not find any total stations there.
http://www.forestry-suppliers.com/product_pages/Products.asp?mi=79692&itemnum=37518&title=Sokkia&%2365533;%20CX-60%20Series%20Total%20Stations
List Price: $7,100.00
Over budget
Offline DDW_OR
« Reply #3 on: October 22, 2017, 07:22:49 PM »
I am looking for what would be the minimum required parts to do solo surveying without a lot of walking back and forth.
to compare this to milling; i am trying to buy the sawmill, but forgetting the log stops, turner, and blade.
for the survey equipment do i need a data collector? or is the data collector the remote controller for the total station.
saw this on ebay
https://www.ebay.com/itm/Topcon-AP-L1A-Robotic-Auto-Tracking-Total-Station-/232493883701?hash=item3621b72135:g:jbYAAOSwCbtZwSbx
or do i need something more like this
https://www.ebay.com/itm/TOPCON-GTS-802A-Robotic-Electronic-Total-Station-Ecellent-Condition-/152747588490?hash=item2390773b8a:g:vcUAAOSwAaJZ5mM0
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #4 on: October 22, 2017, 07:57:04 PM »
Ben Meadows  ;) ;) ;) ;D
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #5 on: October 22, 2017, 07:58:57 PM »
Well,.. how much line will a Registered LS run for 3K??
all you need is inter-visible points, then you can fill in the pieces,
 Total Stations are Line-of-site  instruments
and you have to walk,  data collection (raw) is nice but not useful in the field
unless you can compute with it.  otherwise your writing the angles and distances
and hand computing your way.
GPS to stay on-line?  I'm thinking a stationary base and a rover unit and as little tree cover as possible
With either system you should start with confirmed hard points otherwise your guessing at best which may cause all kinds of troubles later
D
Offline DDW_OR
« Reply #6 on: October 22, 2017, 09:10:15 PM »
Q1 = Well,.. how much line will a Registered LS run for 3K??
Q2 = Total Stations are Line-of-site  instruments
Q3 = GPS to stay on-line?  I'm thinking a stationary base and a rover unit and as little tree cover as possible
FACT 1 = With either system you should start with confirmed hard points otherwise your guessing at best which may cause all kinds of troubles later
D
Q1 = my property has eight PLSS_Corner markers
Q2 = are you referring to a THEODITE?
Q3 = yep that is what i am thinking of. a stationary total station and me walking with the rover unit marking the fence line.
FACT 1 = 100% AGREE. measure twice or even three times, then fence once.
Offline DDW_OR
« Reply #7 on: October 23, 2017, 01:22:39 AM »
what do you think of this one?
https://www.ebay.com/itm/322729250342?&autorefresh=true
just a little over budget, but i like the data collector screen
Offline DDW_OR
« Reply #8 on: October 23, 2017, 04:30:49 PM »
did some more research on the difference between 3" and 5"
3" at 1,500 feet the difference is 0.02ft = 0.24 inches?  1/4 inch?
5" at 1,500 feet the difference is 0.04ft = 0.48 inches?  1/2 inch?
so for a fence line i think i can use the 5" = cheaper
Offline DDW_OR
« Reply #9 on: October 24, 2017, 04:10:10 PM »
I got the Topcon GTS 825A Robotic Total Station w Nomad Data Collector
it had the most stuff for the least $$
Offline dgdrls
« Reply #10 on: October 24, 2017, 06:24:34 PM »
DDW_OR,   Question, have you spoken to the adjoiners about your plans?  those lines are theirs too.
FWIW I would still see what a local LS could provide you for service.
D
Offline chevytaHOE5674
« Reply #11 on: October 24, 2017, 06:54:27 PM »
As a landowner I would NOT be comfortable with my neighbor running the property lines and installing fence no matter what equipment he has. He could run all the lines he wants but when it comes down to it the only ones that matter are the ones a registered and licensed surveyor puts in.
I had 8 corners pinned and registered with the county clerk and a 2.5 miles of lines flagged over the last few years and have way less than 3k invested.
Offline DDW_OR
« Reply #12 on: October 24, 2017, 11:29:49 PM »
I have three tax lots that total 166 acres of hilly/wooded.......
High = 1895
Low = 1657
Land survey costs
Started by Woolywolf on Forestry and Logging
Last post December 27, 2009, 05:18:34 PM
by indiaxman1
My land survey and a possible error
Started by grweldon on General Board
Last post September 17, 2013, 09:23:27 PM
by dgdrls
Is the general public familiar with public land survey system?
Started by bigtrees on General Board
Last post May 30, 2018, 08:35:46 AM
by maple flats
Alternative equipment for land owners?
Started by Groo on Forestry and Logging
Last post October 17, 2011, 10:37:09 PM
by Ironwood
