Draw for handbuilt acoustic guitar get your name in
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: WoodMaster 718 Planer up for sale  (Read 6421 times)
Offline 2StateTrigger
  • Location: Currently N.Tampa but looking at acreage in CO near Pagosa Springs
« on: October 22, 2017, 11:09:39 PM »
I have read and agree to the rules regarding posting items for sale on FF.
WoodMaster 718 Planer/Molder.....18-inch Molder/Planer with 5HP, 220V, 30-amp.,1-Phase, TEFC cutterhead motor, push button Magnetic Switch with thermal overload protection, Variable-Speed 110V, feed system Gearmotor (allows 70 to over 1,000 cuts-per-inch), set of high-speed steel Planer Knives mounted in precision-balanced, 3-knife cutterhead (head can also be used to mount molding knives), set of Steel Infeed and Outfeed Tables (extends bed length to 42-9/16"), Heavy-Gauge Steel Dust Chute With 4" Port, Super-Slick Polypropylene Bedboard With Guide Rails. This is a ZERO time machine. All work was performed by the 718's big brother, the 725. Asking $3000
If interested in any of this equipment interested individuals should email seller ASAP. This is a 1st Come, 1st Served sale. CASH in hand for the planer.
SCAMMERS beware, I will not accept any other form of payments. You will be wasting your time by trying to scam me, so lets cut to the chase and skip by me cause I wont fall for your immature scams.
Serious inquiries only please. I wont waste your time so all that I ask is that you dont waste mine. Fair enough?
Best Regards to All
Molon Labe
Offline rjwoelk
    • countrysidefirewood
Re: WoodMaster 718 Planer up for sale
« Reply #1 on: October 25, 2017, 10:00:37 AM »
I have been eyeing those machines for years. I just would like to talk to some one that has used them extensivley for molding, flooring the whole works. We will be building 2 log homes in the next 5 years and would do all the mill work. What made the desision to keep the 725 over the 718. I have read were folks will have up to 3 when doing production. Has any one gone from log to sawmill to molding , flooring.  What was your production loss, say xboard ft of logs to x board ft of finished product.  Cost and time to run xboard ft.
Sorry you are too far away from me. I seldem get down that way with loads.
Have a great day Bob
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #2 on: October 25, 2017, 10:33:27 AM »
I've got a 712 and just bought a 718 I stumbled on this past weekend.  (I'm still setting up my woodshop one used machine at a time.   ;D)  Others on here have a lot more hours on them than I do though.
http://www.forestryforum.com/board/index.php/topic,92381.msg1422056.html#msg1422056
http://www.forestryforum.com/board/index.php/topic,88892.msg1365611.html#msg1365611
Loss will depend on widths and quality you want as well as the quality of the logs.  Trying to get clear flooring from low quality logs will require a lot of defecting and waste.  Rustic grade from low quality, not so bad.  Sticking to no more than 3 widths seems to work with installation and recovery percentage.
Don't forget kiln drying.
For building two houses, I think the machine would pay for itself.  It won't take a big bite out of the wood, but they are versatile and will do a lot, just not at commercial machine rates (but not commercial machine prices either).
Lucas 6-13+slabber, Mr. Sawmill bandmill, orange chainsaws, JD SSL, Case Backhoe, farm tractors, trailers, and 150ish acres of trees.  Fledgling woodshop with CNC router, laser engraver, Woodmaster 712, and a Berlin 108 moulder (project).  Oh, and a lovely (patient) wife and four offbearers.
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« Reply #3 on: October 25, 2017, 12:25:07 PM »
 For rustic, please make the case for planing versus simply putting the flooring down in its rough milled state and depending on the sanding process.
« Reply #4 on: October 28, 2017, 01:04:40 AM »
What made the desision to keep the 725 over the 718.  Has any one gone from log to sawmill to molding , flooring.
Bob, I purchased both the 718 and the 725 at the same time when I started to set up shop.  I've used the 725 on all of the T&G boards for the pine paneling for my father's sunroom.  I will try to get some pics posted here in the next week or so.
I decided to keep the 725 over the 718 since the 725 has more capacity (width) hence the sale of the 718.
If you're serious about purchasing one of these (regardless if it's mine that you purchase) you can always find someone to help transport it by way of using the transportation forum here at FF....or you can find someone using the "UShip" website where you post items that you're needing shipped and shipping/freight companies bid for the business.  Just a thought if you havent considered it....
Best of Luck to you,
Molon Labe
Offline rjwoelk
« Reply #5 on: October 28, 2017, 02:12:01 AM »
Thanks Jeff for the information.  I am really looking at the 725. I suppose under production more than one machine would save resetting to do different things. Still working on that. Would need a kiln to go with the moldings,  no end in sight,
Offline pineywoods
« Reply #6 on: October 28, 2017, 09:15:29 AM »
The 725 has some upgrades over the 718, more than just width. Fer instance, 4 feed rollers vs 2 on the 718. 2 on the infeed and 2 on the outfeed.
Offline rjwoelk
« Reply #7 on: October 29, 2017, 12:35:34 PM »
I would say that planing them keeps the majority of the dust chips etc in the shop not all over the house.
Offline rjwoelk
« Reply #8 on: October 29, 2017, 12:39:36 PM »
Thanks piney.
I think that it is just a better up grade all around. Now if our Canadian dollar gets back to par I will jump on it.
Offline pine
« Reply #9 on: October 29, 2017, 02:17:52 PM »
2State Trigger
Question
In the third from the last photo there is a device that is to the right of the feed roller rheostat mounted on the frame.  I don't have that on my 718.  What is that?
Offline pineywoods
« Reply #10 on: October 29, 2017, 02:31:05 PM »
2State Trigger
Question
Added on drum switch to reverse the leads going to the feed motor.. which is a dc motor..Reverses the feed rollers... If you haven't seen the need for that, you will  ;D
Offline pine
« Reply #11 on: October 29, 2017, 02:39:32 PM »
Trust me I have seen the need for it and wish I had it, several times over.  I had heard of folks that had done it but had not seen one or heard how they did it.  Since this specific 718 has zero time I guess he modified it without ever using it.
I would guess this is not a manufacture modification and thus since you knew what it was immediately it must be a common part number that you and they used to do it.  Please let me know what the part number is. I will get the part and make the mod.  I can't read the part number in the picture.  Thanks
Offline SlowJoeCrow
« Reply #12 on: October 30, 2017, 09:43:35 AM »
I think they might have changed this on newer 725's... my 725 bought new this year only has two feed rollers.
Offline uler3161
« Reply #13 on: October 31, 2017, 11:22:13 AM »
Here's a link to the reversing switch: http://woodmastertools.com/NS/accessdetail.cfm?PID=41
1989 LT40HD, 12ft extension, WoodMaster 718, Fordson Major Diesel, Champ CB40 Forklift
Dan
« Reply #14 on: January 26, 2018, 08:00:22 PM »
Soo sorry to those who have asked questions and not received an answer from me.
This 718 is still up for sale so if you're interested just send me a reasonable offer.
I've been extremely busy over the holidays and now that it's several weeks after the New Year I've finally remembered to check ForestryForum for questions and such....Again my apologies.
As for the reversing switch IT IS extremely useful especially when you first start feeding planks thru the machine.  It's very useful (and a time-saver) since rough cut planks can have uneven areas.  So instead of running the entire plank thru, which takes time depending on overall length I would simply stop and reverse in times when I noticed areas that the knives werent cutting.
You'll love the reversing switch when you install it.
Email me directly at LumberOneCorp@gmail.com and enter 718 in the subject box if you have questions/comments.  That way I'll be notified quickly.
Molon Labe
« Reply #15 on: March 23, 2018, 07:17:26 PM »
Really need to get this out of the shop....Come with some offers...all I can do is say no....
Molon Labe
Offline Gary Davis
« Reply #16 on: April 07, 2018, 08:41:09 PM »
I paid 1500 for mine
Offline millerik
« Reply #17 on: April 23, 2018, 09:10:50 AM »
Hello interested in your 718 planer.  You can contact me here or millerik at geemail dot com.  I was wondering if you have the 'pro pack' and whether you've done any molding?  Please let me know, it might be time to visit my aunt & uncle & cousins in Tampa.  I'm driving from Maryland :-(
Offline 66Deville
« Reply #18 on: April 24, 2018, 10:03:06 AM »
Hey there! My sawmill partner and I are looking for a planer! We are located in Colorado not far from Pagosa Springs-are you headed this way anytime soon? Very interested!
Thanks,
J.C.
Woodmaster planer/molder SALE?
Started by maxomatic on Sawmills and Milling
Last post October 21, 2011, 10:05:44 PM
by oakiemac
Woodmaster 18" planer/moulder for sale.
Started by oakiemac on For Sale
Last post June 15, 2008, 09:24:05 AM
by oakiemac
Woodmaster Planer - 18" Knives (2 Sets) For Sale
Started by DR_Buck on For Sale
Last post March 30, 2014, 01:40:46 PM
by DR_Buck
Woodmaster planer
Started by millwright on Drying and Processing
Last post March 06, 2012, 07:03:08 AM
by Handy Andy
