KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Adding a thumb  (Read 422 times)
Offline gasman1075
  • I'm lucky
Adding a thumb
« on: October 27, 2017, 01:15:36 AM »
I hate computers...I am adding a thumb to my 3 PT hitch pallet forks. I have the hydraulic valves ordered from Surplus Center and will take it to be welded up after I dry fit everything this weekend.
JD 790/Stihl MS310/Stihl MS261/ MS 461 / Timberwolf TW-P5/ Norwood Skid-Winch
Offline thecfarm
Re: Adding a thumb
« Reply #1 on: October 27, 2017, 08:03:59 AM »
I have not see one on the back. Goog luck with it.
Offline gasman1075
  • I'm lucky
Re: Adding a thumb
« Reply #2 on: October 27, 2017, 08:15:03 AM »
I couldn't find one on the back either where my hydraulics are ( power beyond). Ordered the 3 pt pallet forks from Titan and the thumb from Green's Machine. I figure I can back the forks under a log, pinch it, lift it, move it over to where I pile the rounds and then buck it up to length without having the log on the ground while I cut. I hope it works as I hope. It is a lot less complicated than adding the thumb to the bucket. ( I believe )
Offline hedgerow
Re: Adding a thumb
« Reply #3 on: October 27, 2017, 03:56:14 PM »
Should work just fine. I use my grapple fork on my skid steer to hold logs to be bucked with a chain saw. Years ago we did everything on the back with a three point until we got a loader tractor big enough to handle round hay bales and never looked back. Know that I wear glasses I hate using three point equipment backing up.
thumb
Started by woodmills1 on Wanted
Last post May 29, 2009, 07:01:39 PM
by cheyenne
3 PT Thumb
Started by gasman1075 on Firewood and Wood Heating
Last post November 22, 2017, 09:33:10 AM
by gasman1075
My rule of thumb
Started by ddcuning on Sawmills and Milling
Last post December 15, 2013, 07:34:09 PM
by Banjo picker
rule of thumb logs value
Started by rickhise on Forestry and Logging
Last post February 10, 2014, 07:42:33 PM
by rickhise
