Arborwear
Author Topic: Adjusting oiler?  (Read 515 times)
Offline MNBobcat
Adjusting oiler?
« on: October 27, 2017, 08:15:59 AM »
Hi Guys,
I'm curious if everyone turns the bar oiler adjustment screw all the way up (highest flow) on their saws? I was thinking about that and as long as there is still oil left in the reservoir at the end of a tank of fuel, I can't see why you wouldn't run it wide open.  Oil isn't that expensive.  I've never had a saw oil so much that it gets me full of oil so I don't see a down side.
Anyway, was just curious what you guys do.  I've got a brand new Dolmar/Makita 6100 with 20" bar.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: Adjusting oiler?
« Reply #1 on: October 27, 2017, 08:57:26 AM »
Yep, all mine are wide open.
They don't throw the oil like they used to.
Apparently saws sold in the us had to cut back on the amount of oil the oilers throw for environmental concerns.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline btulloh
« Reply #2 on: October 27, 2017, 09:06:10 AM »
I run it wide open on the new saw and it still looks dry compared to the older saw.  It is getting enough oil, but the new oiling rate is kind of uncomfortable after all these years of throwing oil.  I reckon if there's oil left in the tank when the gas runs out, things are good, just like you said.
HM126
Offline John Mc
« Reply #3 on: October 27, 2017, 04:23:25 PM »
It depends on the oil I'm running. I've found the veggie-based oil I use seems to lubricate better than the petroleum oil, so I leave the oiler set at mid-range when I'm running that. I turn it up when running petro-based bar oil.
Offline JohnW
« Reply #4 on: October 28, 2017, 08:44:08 PM »
I think it is possible to have more flowing than the oil channel can handle, so it will be a little messy around there.  But I don't mind.
Offline d1hamby
  • I love to chop things up.
« Reply #5 on: October 28, 2017, 08:54:51 PM »
On my MS362 the oiler is barely adequate with a 16" b&c turned all the way up. With larger b&c I take lots of breaks to oil the chain with slow rpm out of the wood. Essentially I'm polluting more because of poor oiler. Might have to try veggie oil in between regular oil sometime.
Own a Stihl 362 16" 0.050" carbide and steel, and 25" 0.063" Stihl 020T
Stihl KM131R, 130R and KM56R with several Brush Cutter and Weed Trimmer heads. Pole Pruner (with 10", 12" w/wo Carbide, and 16" bar&chains) , Blower, Modified 135 Hedge Trimmer, Straight Edger, Bed Edger, Tiller Kombi attchment
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #6 on: October 28, 2017, 09:11:01 PM »
My 362 is very lite on the oil as well, but it will leave an oil line on a tin building with an 18" bar while cutting a 16" sassafras that was growing to close to it. Oh and it doesn't matter how much oil your saw can produce it still wouldn't cut cast iron window weight that a tree has grown around. A rusty cast iron window weight looks almost identical as a tree root.
Offline Al_Smith
« Reply #7 on: October 28, 2017, 09:47:30 PM »
 :D Well you found metal and it doesn't cut well .Try an electric fence insulator some time .It will clean off 4 teeth before you can shake a stick at it .
I hit a steel  fence post inside a 24" dead ash and not only detoothed the chain but wiped out the drive rim at the same time .Nasty business .Turned a 32" chain loop into a 20" in about 2 seconds .--stuff happens .
Adjusting lt 40
Started by Woods on Sawmills and Milling
Last post November 25, 2017, 08:02:18 AM
by drobertson
Adjusting carb
Started by vinc5d on Chainsaws
Last post February 15, 2015, 11:00:58 AM
by vinc5d
Adjusting the carb on my new saw
Started by 21ftnitro on Chainsaws
Last post March 17, 2015, 10:26:38 PM
by Andyshine77
adjusting carb
Started by momark on Chainsaws
Last post March 28, 2014, 11:14:36 PM
by momark
