Arborwear
Author Topic: Bar and chain  (Read 1306 times)
Offline Rob30
Bar and chain
« on: October 28, 2017, 06:03:49 PM »
How often do you do major maintenance to a bar and chain?  I use a hand file to sharpen when my chain is dull. It works good most of the time. However my saw is cutting arcs now to the left. Not sure if I take the chain to get professionaly sharpened if that will fix it. I filed my bar which helped a little.
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Bar and chain
« Reply #1 on: October 28, 2017, 06:49:43 PM »
After a while the grove in the bar becomes warn out too they have devices that will close the bar back to specs, or just replace the bar. It all depends how much time you want to invest into it. How often do you flip your bar over when you cut ?
Offline PNWRusty
Re: Bar and chain
« Reply #2 on: October 28, 2017, 07:39:24 PM »
Major maintenance, only every 20-40 cords. And it's best to not wait until your chain is dull before sharpening it. I just give it two or three light swipes with a round file every couple of hours. In dirty wood maybe every half hour of actual cutting. But I avoid dirty wood whenever I can.
You can fix the curved cutting by identifying where you went wrong and bringing it back into balance with your round file.  To do this you will need to carefully inspect the angles you cut and compare them (left cutters vs. right cutters). Then, once you know where you went wrong you can compensate next time you sharpen to avoid creating the same mistake all over.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
Re: Bar and chain
« Reply #3 on: October 28, 2017, 09:35:42 PM »
Mine will do that if I hit a rock or wire on one side of the chain and not the other.
Quickest check is to put a new chain on.  If it is still arcing, it's in the bar.  If not, a good grind on the chain should fix the issue.
Offline Rob30
Re: Bar and chain
« Reply #4 on: October 28, 2017, 10:45:25 PM »
Never thought about changing chains to verify if it is the chain. I did notice the left side has shorter knives,  so I started filin g the right side a couple extra strokes each time. I flip the bar everyone I have it off. No schedule. But I will have to start. I am running 1 saws a husky 455 and a 51.
Offline Jesper Jepsen
  • Owner of Mandoghus.dk
Re: Bar and chain
« Reply #5 on: October 29, 2017, 01:56:00 AM »
If your tooths aren't the same length the chain will pull to the side with the short tooth. It happens mostly because we all have a side that is our favorite side when filing and even if you take the same amount of strokes one side cuts a bit more that the other and the you have the problem over time. The solution is to find the shortest tooth and file all the others down to match.
http://www.madsens1.com/bnc_cut_pull.htm
Offline thecfarm
Re: Bar and chain
« Reply #6 on: October 29, 2017, 07:41:08 AM »
I don't want anyone to do what I do.  :D Disclaimer. I am no expert.
I have been running a chain saw for more than 30 years. Firewood,claiming back grown up pastures. I cut wood on my land for 3 years selling logs to sawmills,had white pine over 3 feet across was a normal tree.
Cutting trees in the grown up pasture,trees was cut low,lots and lots of filing the chain. Than when the dirt settles down around the stumps,I had to go back and recut the stumps again.
My saws,I have 2 a 372 Husky and a small efco,gets used ALOT. I mix the highest grade of gas that I can get at my local gas station 4 gallons at a time.
I can hold onto the rear handle of either saw and it will draw itself into the wood. Must be doing something right. I don't cut much hardwood.probably white maple is the hardest I cut. I try to leave the red oak for sawlogs.
I have never once had any problems with the bar causing cutting problems. I do not flip the bar probably when I should. I do not dress the bar.
I do not use the raker gauge when I take down the rakers,I just guess at it.
When the saw does start to cut at an angle,I put the motor on the right side and I take  2-3 swipes with the file on that side and that will get it cutting straight again.
I am not one of these guys that have to cut 10 cords of wood a day either. I cut what ever I cut in a day.
All the above may sound like.That will never work or help. But it works for me.  ;D
Offline Grandpa
Re: Bar and chain
« Reply #7 on: October 29, 2017, 11:25:41 AM »
I file the chain with a file guide every tank of gas. The chain is never allowed to get dull. Dull chain is hard on operators,saws, and really hard on bars.
The bar is dressed and flipped every time I put on a new chain.
I look at it this way, the best accessory for a chain is a well tuned powerhead, not the other way around.
Cutting crooked is a chain problem one way or another. If your bar is worn crooked it is because of an improperly filed chain.
Just my opinion. Good luck.
Offline Wood Shed
  • Retired antique tractor guy enjoying my Tree Farm
Re: Bar and chain
« Reply #8 on: October 29, 2017, 12:03:05 PM »
I am mostly in agreement with of the comments so far.  The best thing I ever did for my chain and bar was to get a 2 in 1 Filing Guide from my Stihl dealer.  Now as I file the cutters I am also filing the depth gauge.  Makes my chains last longer and every aspect more efficient .
A society grows great when old men plant trees whose shade they know they shall never sit in. -Greek Proverb
Offline HolmenTree
Re: Bar and chain
« Reply #9 on: October 30, 2017, 09:35:50 AM »
Wood Shed, is that a John Deere R in your avator? I was thinking a D but there's no air cleaner stack and the front end is too long.
We had both tractors on our Saskatchewan farm back in the 1960's early 70's, nothing beats the sound of those big twins.
Yes the Stihl 2 in 1 guide is good, probably the best on the market. I file free hand but since starting a sharpening business I bought a 2 in 1 just to help straighten up other people's attempts on sharpening their chains.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Bar and chain
« Reply #10 on: October 31, 2017, 12:42:47 PM »
   Certainly no expert but I flip the bar every time I change chains (or try to remember to do so). I am no good with a file and use the Dremel tool type sharpeners with the angle guide built in. Otherwise since I am right handed I cut one side too much and get the arc described earlier. With these 12V sharpeners I am pretty consistent in grinding and get good straight cuts.
   I have used Oregon, TSC and Sthil sharpeners. All are pretty good. Sthil makes you use their threaded stones and the switch is on the cord requiring 2 hand operation to turn it on or off. I prefer the other 2 so I can use stones from any source and they have the switch on the sharpener so you can use and turn it on and off with one hand.
   These sharpeners have alligator clamps that hook to your 12V ATV, truck or mill battery for sharpening on site/in the field which is more convenient than the big shop sharpeners.
Offline Philbert
Re: Bar and chain
« Reply #11 on: October 31, 2017, 02:06:24 PM »
I try to keep up, so that there is no 'major' maintenance; flip the bar each time it is removed; file or replace the chain(s) in the field when dull; clean the saw(s) at the end of each day, and clean / check for burrs / wear / etc. on the bar.
Some of this depends on how you use your saw(s).
I periodically do 'major' maintenance on bars and chains when I get some used ones, or work on some others' saws. I sharpen with a grinder at home, so that keeps the cutters 'evened up'.  Some hand filed chains need this periodically.
Philbert
Offline Wood Shed
Re: Bar and chain
« Reply #12 on: October 31, 2017, 02:34:16 PM »
HolmeTree,
That tractor in my avatar is a 70 gas standard.  I like the two cylinder standard tractors and have four other models.  John deere two cylinders I grew up with were all tricycle (narrow) front tractors.
Offline HolmenTree
Re: Bar and chain
« Reply #13 on: October 31, 2017, 06:48:02 PM »
HolmeTree,
That tractor in my avatar is a 70 gas standard.  I like the two cylinder standard tractors and have four other models.  John deere two cylindders I grew up with were all tricycle (narrow) front tractors.
Wood Shed, your 70 looks to be in show room condition.
My Dad taught me how to flywheel start our old AR when I was 10. Something you never forget , like learning to ride a bicycle. My favorite was the newer D we had, great for on the breaking plow or running the belt on the buzz saw.
Offline HolmenTree
Re: Bar and chain
« Reply #14 on: October 31, 2017, 07:15:51 PM »
Philbert
I've always filed my chains free hand until I started recently in the business of sharpening others who attempt to file or use a dremil.
Most times people have a dull file and get too much back slope in their cutters sideplates. Or they use a dremil and go way too deep in the gullet.
So I find the Stihl 2 in 1 guide helps me not have to fight with those crazy angles.
If their chain is badly rocked out or cutting edges are too hard from a Dremil I take my cordless 4.5 angle grinder and gently bring the cutters back to good, then finish off with the round file.
Only grinder I've ever used on a chain.
Offline Canadiana
  • I was new a while ago
Re: Bar and chain
« Reply #15 on: October 31, 2017, 08:15:15 PM »
Good test for uniform bar wear: Remove it and set it on a flat surface so it balances in the same position as an upright saw. If it won't balance. It's done. People have told me they've ground/filed theirs back into balance but i haven't seen it done, seems like machinist work. If it will balance, the tilt or the gaps between the flat surface and bar will show you the amount of wear and location. Keep em oily. Keep flipping em over. Keep filing em.
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
Offline Al_Smith
Re: Bar and chain
« Reply #16 on: October 31, 2017, 08:57:02 PM »
That comment on a JD A can not compare to rolling over a JD 70 standard .That big boy is 412.5 cubic inches and did not come with petcocks although they can be installed .Without same you need to have arms of a gorilla . 6.125 inch  bore,7 inch stroke .I have a standard tricycle front  all fuel,1954
Offline HolmenTree
Re: Bar and chain
« Reply #17 on: October 31, 2017, 09:58:00 PM »
Actually the AR at 321 cubic inches was a substantial engine for a 10 year old boy to turn over by hand, yes I used its petcocks.
But didn't take me long to get onto our D . That old monster at 501 cubic inches with the bigger flywheel was a breeze to turn....both brass petcocks hissing with raw gasoline.
 The old D we had was a newer model with electric starter but like a old school Harley Davidson rider this farm kid still preferred to turn that flywheel by hand.
BTW there's a JD AR at Barrett Jackson's auction priced at $27,500.
Offline HolmenTree
Re: Bar and chain
« Reply #18 on: October 31, 2017, 10:32:40 PM »
I mentioned earlier the birthplace of John Deere was Ohio. My mistake I miss read Iowa as Ohio.
John Deere originated in Waterloo Iowa
Offline Al_Smith
Re: Bar and chain
« Reply #19 on: November 01, 2017, 06:28:10 AM »
While on the subject just as a reference the JD model R they did the Nebraska test on resides near LaFayette Ohio .How it got there I have no idea .
Mill Chain, Heavy Duty Conveyor Chain' etc
Started by splitter on Wanted
Last post July 12, 2008, 11:34:36 AM
by TexasTimbers
Oregon Chain Grinder vs. Stihl chain angles
Started by Chelsea Tree on Chainsaws
Last post July 08, 2013, 07:58:36 AM
by bandmiller2
question
Recomendation for chain saw & chain for wood slabs
Started by Mike in Texas on Chainsaws
Last post October 29, 2017, 01:33:30 AM
by Ianab
Saw chain sharpening and or chain makeing in upstate ny
Started by justintimemoto on Services
Last post May 19, 2010, 04:28:59 PM
by justintimemoto
