Arborwear
Author Topic: Blue spruce roots  (Read 460 times)
Offline brianJ
  • Only get excersize if I choose the right hobby
Blue spruce roots
« on: October 29, 2017, 05:39:35 AM »
Do they have a tap root?   How far do the roots spread out?     Is it feasable to pull out a stump with a farm tractor?   or more accurately what size stump may a 100 hp four wheel drive pull out?
Offline PA_Walnut
Re: Blue spruce roots
« Reply #1 on: October 29, 2017, 07:48:35 AM »
Roots go out about as far as the limbs, and yes there's a tap root.
Do your self a favor (ask how I know  :-\) and push the tree over BEFORE cutting it or leave a good amount for leverage in pushing over the stump.
The first one I cut about 1 foot off the ground and it took me about 2 hours to dig it out with my backhoe.  >:(
Second time I dug for <10 minutes, reached my bucket up hight and pushed it right over. WAY WAY easier.
Good luck.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Online DDW_OR
« Reply #2 on: October 29, 2017, 10:52:53 PM »
yep, dig the ground on at lease two adjoining sides, then push.
I use a 3 foot long ripper tooth on the Excavator.
since it sounds like you want the roots then how about using a high pressure water hose, maybe a fire hose?  dig a drainage ditch, then water blast the roots.
TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Multitek 1610EZ
Offline brianJ
« Reply #3 on: November 06, 2017, 05:14:38 PM »
Thank You guys.    I got 6 blue Spruce growing in a field the boss just bought and they are in the way.    Cutting them down just leaves stumps in the way so not really helpful.   Sounds like a 4 wheel drive tractor and a well used chain with the Husky can take care of it.
or thats my plan.
Little Blue Spruce needs help!
Started by LUV2MILL on Urban and Community Forestry
Last post December 06, 2015, 07:41:33 AM
by timberlinetree
Blue Spruce
Started by beerguy on Sawmills and Milling
Last post July 12, 2004, 01:37:15 AM
by Ianab
Blue spruce...
Started by Ever Green on Forestry and Logging
Last post May 31, 2007, 10:32:59 PM
by sjh
Blue Spruce?
Started by Nate Surveyor on General Woodworking
Last post March 14, 2008, 01:43:01 AM
by Coon
