Author Topic: Honda gx390 problem  (Read 1482 times)
Offline Bigmikessmallen
Honda gx390 problem
« on: October 29, 2017, 04:54:50 PM »
Sorry if this is the wrong place to post but i couldnt find the correct sub. Anyways my honda gx390 has an electric start problem it sounds like the battery is not giving it enough power to turn the starter. So i replaced the battery with new and the problem still persists. Could this be a bad solenoid? Any help would be greatly appreciated.
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Honda gx390 problem
« Reply #1 on: October 29, 2017, 05:31:05 PM »
How corroded are your battery wired and hows your ground wire, both will cause electric delivery issues. You can check the solenoid by jumping the contents with a screwdriver, if you complete the circuit across the top and it tries to start then the solenoid is the problem.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: October 29, 2017, 05:56:22 PM »
Easy check... Just hook a jumper cable between the pos. on the battery and the large
lug on your starter. If that don't work hook the jumper to Neg. on the battery and clamp
the other end to the engine block. Caution. The engine will try to start on it's own when
doing the first one. The first will one find a solenoid or wiring problem and the second will
find a grounding problem.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline North River Energy
« Reply #3 on: October 29, 2017, 06:42:07 PM »
Did this problem come 'out of nowhere', or has the motor been cranking slower and slower over time?
If the easy stuff yields no results, make sure the brushes are making good contact with the armature, and that the armature is still 'round' in the area of contact.
Also, would help a little to know what the motor is turning.
« Reply #4 on: October 29, 2017, 07:50:31 PM »
I tried jumping the solenoid earlier from the positive terminal to the little clip on the solenoid and it sounded like the starter wants to engage but doesnt.
What do you mean by what the engine is turning river?
« Reply #5 on: October 29, 2017, 07:52:17 PM »
And yes it has been crankin slower and slower over time. Thats what made me think the battery was bad which it was anyways so i got a new one and its still acting as if the battery has no juice.
« Reply #6 on: October 29, 2017, 08:29:37 PM »
What kind of machinery is the motor powering?
Compressor, power washer, log splitter, generator trash pump, elevator/stacker, ferris wheel, etc.
Brother once had a Honda street bike that cranked poorly, and it turned out the armature was worn into 8(?) lobes rather then being round.
« Reply #7 on: October 29, 2017, 08:47:59 PM »
Ohh its a cormidi 85 mini dumper. Hrmm so would it be worth just buying an entirely new starter with solenoid attached instead of just getting an armature?
« Reply #8 on: October 29, 2017, 10:34:10 PM »
^Don't know, but it's worth checking the condition of the brushes and armature if the simple tests don't reveal an easy fix.
Does the  motor spin easily with the pull cord, and does it run well otherwise? Is there anything in the dumper driveline that could be engaged when it shouldn't be, thereby loading the starter?
Offline sawguy21
« Reply #9 on: October 29, 2017, 10:41:23 PM »
Does the engine have a lot of hours on it? Check the valve clearances, should be INT .006" EXH  .008" If they are excessive the automatic compression release won't work.
Online btulloh
« Reply #10 on: October 30, 2017, 08:59:19 AM »
X2.  Had this happen on several engines.  Should make it part of annual maintenance.
HM126
Offline Kbeitz
    • My Hobbies
« Reply #11 on: October 30, 2017, 01:49:56 PM »
You can buy a new starter off Ebay sometimes cheaper than buying brushes.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: October 30, 2017, 07:27:40 PM »
Follow Kb's Reply #2 above and do some troubleshooting before you start throwing parts at your problem.
« Reply #13 on: October 31, 2017, 08:08:14 AM »
So KB just so i understand hook the jumper cable from positive battery terminal to the large lug but there are 2 lugs on this starter im assuming connect it to the ground lug on the starter? Sorry ive never jumped a starter
« Reply #14 on: October 31, 2017, 08:09:14 AM »
Also sorry for the delayed response thank you all for your input it definately gives me some direction on where to go from here.
« Reply #15 on: October 31, 2017, 08:11:46 AM »
The machine runs fine , there is no load on the motor. Runs well with the pull cord its just a hassle having to pull this thing everytime especially when the motor kicks back and rips the pull cord out of your hand lol.
Online btulloh
« Reply #16 on: October 31, 2017, 09:09:04 AM »
Jumping the starter is a great place to start.  It answers a lot of questions with minimal time invested.
Don't discount the possibility of the valve clearance causing a problem with cranking.  If it's still cranks slow with the starter after jumping, it would be my next thing to do.  There is a de-compression lobe on the cam that works at low (cranking) rpm.  It has a big effect on starting torque required.  Adjusting the valve lash is easy and takes ten minutes or so.  It doesn't take a million hours before it gets out of whack.
Valve lash doesn't seem like it would be such a factor - until it's happened to you a couple times.
Good luck with the problem.  It's a good engine and you'll get it sorted out.
HM126
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: October 31, 2017, 09:28:53 AM »
And remember that being absolutely sure that you have a good ground is of the utmost importance.
Offline sawguy21
« Reply #18 on: October 31, 2017, 11:57:22 AM »
That is also a sign the valves are out of adjustment
Online btulloh
« Reply #19 on: October 31, 2017, 04:45:10 PM »
True that ground check MM.  That's certainly the first thing to check before the other first thing.
HM126
Problem with my Honda
Started by ohsoloco on Sawmills and Milling
Last post November 02, 2002, 07:57:48 AM
by GarryW
Honda 5.5 problem......with solution
Started by woodmills1 on General Board
Last post July 07, 2008, 09:54:48 AM
by ely
24 horse honda problem
Started by mac on Sawmills and Milling
Last post June 26, 2007, 01:31:52 PM
by solidwoods
Honda G400 problem
Started by Apiti Jack on Forestry and Logging
Last post October 18, 2016, 04:08:58 AM
by Apiti Jack
