KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Stihl ms 461  (Read 2218 times)
Offline Ptayls
Stihl ms 461
« on: October 30, 2017, 11:28:09 AM »
Hello Iím new to this forum. Iíve been cutting wood for a few years,Iím an amateur Chainsaw user and mainly use a mtronic ms 261. Iím cutting large fallen beech and oak trees and fine my current saw too small as some trunks of these trees are 30-35 inch in diameter. I would like to get a larger saw like the Stihl ms 461 and put a 25 inch bar on it. What put me off is that fact it has an adjustable carburettor and I would struggle to retune it when the need arises. Is it as difficult as Iím imagining or is it relatively easy? I have seen that the Stihl ms 462 is out in the UK next year,mtronic,Iím thinking maybe I should wait for that. Any help and advice would be much appreciated
Offline pine
Re: Stihl ms 461
« Reply #1 on: October 30, 2017, 11:57:46 AM »
Might be me but I have a strong preference for the adjustable.  I replaced my 460 several years ago to avoid the 461 that was coming out and I would do the same in your situation.
Can't stand all this auto stuff. One more thing to break and on top of that there is a lot of anecdotal evidence that the auto tuning is running way too lean and folks are having issues.  Maybe not but it sure seems that way.
Offline Ptayls
Re: Stihl ms 461
« Reply #2 on: October 30, 2017, 12:21:33 PM »
Are they easy enough to adjust though? Any after you buy a new saw thatís set at factory settings do they need to be re-tuned within a short time? Thanks for reply
Offline HolmenTree
Re: Stihl ms 461
« Reply #3 on: October 30, 2017, 12:33:37 PM »
My latest adjustable carbed  saws come with limiter caps with a special tool slot in the heads.  That  special head screw driver is not available to order. The dealer has thst special tool.
So I ended up removing the caps and then was able to get at the adjustment screws with a regular flat screw driver.  Real pain to remove the caps plus your warranty is voided when they've been tampered with.
I have good experience with the latest Stihl MTronics
The Husky AutoTune not so much.
Offline ButchC
Re: Stihl ms 461
« Reply #4 on: October 30, 2017, 12:47:51 PM »
I am an adjustable carburetor guy also ( I bought a 461 because it is so equipped)  but I also see merit in these  new fangled automatic fueling systems.
Unless you are hauling it up and down mountains or running with dirty air filters or junk fuel you dont have to screw with the carburetor to keep a saw running right. I rarely touch the screws on my saws once set, Ill bet it has been 10 years since my 036 has seen an adjustment.  Let the dealer set up the 461, take it back for a reset after 10 tanks of fuel and  worry about it no more unless you note some change in operation.
That being said the 462 will have better anti vib and the Mtronic seems to be working well on the other models.  I would bet that there will be a pretty big jump in price over the current 461 and there is a weight consideration too.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline pine
Re: Stihl ms 461
« Reply #5 on: October 30, 2017, 12:52:00 PM »
Now that I think about it most of the anecdotal problems I have heard about are from the Husky line of autotunes.
Interesting
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: Stihl ms 461
« Reply #6 on: October 30, 2017, 01:06:39 PM »
I haven't had to adjust my 461 yet. We don't keep track of tank fulls but it's probably had between 15 and 20 gallons through it. None of my jonsered or huskys with the adjustable carb ever need to be adjusted very often my newest 2166 is a little over a year old and I haven't had to mess with it yet
Offline Ptayls
Re: Stihl ms 461
« Reply #7 on: October 30, 2017, 02:04:48 PM »
Thank you all for your replies,sounds like the 461 wonít be as difficult as I imagined and probably cheaper than the new 462 will be to buy
Offline PNWRusty
Re: Stihl ms 461
« Reply #8 on: October 30, 2017, 02:33:38 PM »
It doesn't take long to tune a manual tune saw so don't let that scare you off. And you can probably get away with never tuning it once it's broken in and running well.
But here's the deal. If you're not re-tuning when you get a new can of fuel, change altitude or are in a high or low pressure weather system, chances are your saw is not tuned very well. A little rich won't hurt anything but you will be filling your tank more often and you might carbon up a bit more over time. On the other hand, you can destroy your engine if it's too lean. A saw equipped with Mtronic is always in tune. So no worries. It's proven to be a very robust system and I think I've noticed less Mtronic owners reporting piston scoring/seizures. Because it's paying attention even when you're not.
So while I never had any trouble keeping my 026 well-tuned, I certainly appreciate the automatic tuning of my 261 C-M. Some people are tech shy so maybe Mtronic is not for them and some people are proud that they know how to tune a saw so they don't want a chip doing it for them. But I've always been a practical guy. Even though I learned to drive using a stick, and never really liked automatics, I didn't avoid them because I was too proud or too manly to let the car shift for me, I avoided them because they only had three speeds, they were inefficient and felt "wrong" to me. As soon as manufacturers came out with crisp shifting A/T's with 4-9 speeds, I had no problem with buying an A/T. Mtronic is a proven system and one of good benefit.
Offline teakwood
  • Switzerland
Re: Stihl ms 461
« Reply #9 on: October 30, 2017, 07:17:42 PM »
If you don't know how to tune a saw i would recommend you get a autotune. or let your stihl dealer do it
Offline PNWRusty
Re: Stihl ms 461
« Reply #10 on: October 30, 2017, 07:38:14 PM »
I would recommend learning how to tune a saw before becoming dependent upon a dealer. It would be impractical to take it to the dealer every time you had a doubt about your mixture! Of course with Mtronic you don't have to worry about either.
Offline teakwood
  • Switzerland
Re: Stihl ms 461
« Reply #11 on: October 30, 2017, 09:22:00 PM »
I am sure that most chainsaw owners can't tune a saw!  I use chainsaws since age 16 (not full time) and i can tune a saw so she works fine but i'm by no means an expert on tuning.
Offline HolmenTree
Re: Stihl ms 461
« Reply #12 on: October 30, 2017, 10:09:42 PM »
Best word of advice how to tune your saw is read the owner's manual.
Offline Ptayls
Re: Stihl ms 461
« Reply #13 on: October 31, 2017, 04:13:21 AM »
Thanks for the advice everyone
Offline burtle
Re: Stihl ms 461
« Reply #14 on: October 31, 2017, 11:31:29 PM »
I'm getting ready to pull the trigger on a ms461 as well!
There's one shop that has one left in stock. They want 979.00 for it. 28" bar.
The other stores said they can order me one but it would be around 1,250 with taxes.
Thanks for all your guys's advice (Sorry OP, not trying to hijack your thread)
Never Give Up
Offline HolmenTree
Re: Stihl ms 461
« Reply #15 on: October 31, 2017, 11:40:28 PM »
Welcome to Forestry Forum burtle!
Offline burtle
Re: Stihl ms 461
« Reply #16 on: November 05, 2017, 11:24:16 PM »
Thank you! I'm really enjoying my stay. Tons of great info on here as you know.
Never Give Up
Offline khntr85
Re: Stihl ms 461
« Reply #17 on: November 15, 2017, 12:50:38 PM »
You do understand  that the 461 has an ADJUSTABLE carb right!!!!
 It has a Limiter Cap in the H-jet, but anyone who can eat with a fork and knife can solve that problem....
Offline khntr85
Re: Stihl ms 461
« Reply #18 on: November 15, 2017, 12:58:34 PM »
Well I am here to tell you guys, 9 out of 10 tree guys around me locally donít ever re-tune a saw their whole entire career!!!!
 As a matter of fact most average chainsaw users donít have a clue about tuning a chainsaw....
 If you use a saw a lot, yes you should know how to tune it...if you have good hearing, itís simple....
 As far as the 461, go buy one today.....they are great saws....I have had one for 2-years now, no problems whatsoever....
  I cut hardwoods mainly, and keep a 25Ē bar on my 461....I have to drop a maple a few months ago and got a chance to see what she could do with a 32Ē bar.....well I am here to tell you I was shocked how well the saw did.....I wonít be scared to slap the 32Ē on agian if I need to....
Offline Greenerpastures
Re: Stihl ms 461
« Reply #19 on: November 19, 2017, 12:47:40 PM »
I would get the 461, it will cost less, and as others have
said, ensure your dealer checks the tune before taking the
saw home.
And bring it back after a month, and even pay to have it re
cheked, it is a small fee for real peace of mind.
In any event, the real danger with tuning is when you take a
saw that was tuned high altitude down to low altitude,
the saw will become much too lean, and will fry,
so it is better to tune for low altitude,
this way if you climb your saw will be too rich, and at least will
not be fried.
I recenty ended up with a 362 mtronic, but this was due to
circumstance, there was no non mtronic saws available in
Stihl, and I could not wait on another brand or saw to arrive
at my place.
If I had time to wait on another saw, I would have been getting
a Dolmar or Makita 6100, and if not available, a Shindaiwa or Echo
CS-620, they are great saws too.
Let us know what you settle on.
Regards, john
Mounting Cannon S2 (big Stihl) 42" bar on MS661 (small Stihl)
Started by neildorin on Chainsaws
Last post September 11, 2017, 06:01:44 AM
by Al_Smith
Does Stihl have a different mount size at the studs for bigger and smaller Stihl
Started by quietrangr on Chainsaws
Last post October 09, 2011, 08:25:11 AM
by Al_Smith
There are Stihl dealers then there are Stihl sellers.
Started by Ward Barnes on Chainsaws
Last post January 31, 2012, 11:16:22 AM
by tcrew
Stihl M391 vs Stihl M261
Started by alabama on Chainsaws
Last post February 26, 2017, 07:35:56 PM
by alabama
