Arborwear
Author Topic: Central Boiler 4436 question  (Read 272 times)
Online JB Husky
« on: October 30, 2017, 06:46:16 PM »
I bought a second hand CB 4436 and I'm confused about my digital display. I'm getting swings of 10-15 degrees on the display as I open and close the door. In the past on an OWB that I built I was using a Ranco aquastat and there was very little change in the temperature. I'm wondering how accurate the factory display is. Any thoughts? I have a thermowell plumbed into my piping at the stove so I could go back to the Ranco but it's a bit of a hassle since I just re-wired the stove using the factory stat. Thanks in advance!
455 Rancher
562 xP
Stihl 460
Echo 750 EVL
Antique Brave splitter
Offline boilerman101
Re: Central Boiler 4436 question
« Reply #1 on: November 02, 2017, 10:36:07 PM »
Does that model have an adjustable controller or can't you make set point adjustments?
Online JB Husky
« Reply #2 on: November 04, 2017, 06:50:07 AM »
No. The set point is fixed.
455 Rancher
562 xP
Stihl 460
Echo 750 EVL
Online E Yoder
  • Heating with a HeatMaster GS100
« Reply #3 on: November 04, 2017, 09:02:45 AM »
Where is it sensing temperature? Is there any possible way it can be affected by the return water from the house?
Is the probe seated all the way in the dry well?
Just brainstorming ..
HeatMaster dealer support in VA.
GS100.
« Reply #4 on: November 04, 2017, 02:03:13 PM »
JB, if non adjustable what you have in that older 4436 is a readout only water temp display with sensor screwed directly into a water jacket bung. You also have a separate fixed aqauastat that opens and closes the damper solenoid that is screwed into a separate bung in the waterjacket. Both componants may have different tolerances so there could be some variances. If numbers get erratic when opening and closing door, I'd check for loose connections on those componants. I think in 2003 CB went to adjustable controllers.
Central Boiler question
Started by JEBIII on Firewood and Wood Heating
Last post January 08, 2012, 01:30:33 PM
by Dean186
Central Boiler Eclassic 1450 question
Started by Ebwheat on Firewood and Wood Heating
Last post May 09, 2016, 05:55:48 AM
by garret
central boiler 6048 anti freeze question
Started by adamant on Firewood and Wood Heating
Last post September 24, 2013, 01:56:25 PM
by go green
Question about Checking my water on my Central Boiler with the test kit
Last post December 21, 2015, 05:04:51 PM
by doctorb
