Arborwear
Author Topic: Chimney on outdoor wood furnace  (Read 1366 times)
Offline Woodcutter_Mo
Re: Chimney on outdoor wood furnace
« Reply #20 on: November 05, 2017, 12:11:08 PM »
that helps alot.
looks like you are between a rock and a hard place ;D
 Yup, I'll make it work out one way or another. It's just requiring a little extra effort and $$$, but I think it'll be worth it in the long run.  ;D
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball bale/dump bed, '07 Honda Rancher
« Reply #21 on: November 09, 2017, 12:55:33 PM »
 I found some elbows and a Tee w/clean out cap on eBay. They should be here within the next several days so I can mock up where the pipes will go to figure out exactly where to place the antenna.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #22 on: November 09, 2017, 01:02:08 PM »
Heating the shop at the same time?
oops. nevermind that says driveway :)
I knew what I thought I meant.
« Reply #23 on: November 09, 2017, 03:08:18 PM »
 If it were a boiler I would definitly heat the garage with it :)
« Reply #24 on: November 25, 2017, 09:14:52 PM »
Got a start on the chimney, I bought a Selkirk "T", a Selkirk 30 elbow to come off the T. Also using the two 30 elbows from a super vent 30 offset kit to attach to the furnace since that's what the stove is setup for. I used my Selkirk anchor plate as an adapter to connect the Selkirk pipe to the SuperVent elbows. Sounds like alot of work but I saved several hundred dollars combined just on these pieces getting them from eBay.
 We put up the antenna tower set in concrete next to the furnace to mount the chimney to.
 Here's where I'm at now, I'll have to figure out a good sturdy way to attach the chimney to the tower sections but just using some steel strap for mock up.
Offline DDW_OR
« Reply #25 on: November 25, 2017, 11:39:33 PM »
Now put a weather station on the top of the antenna tower
i have the Vantage Vue, the remote sensor is solar powered
TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Multitek 1610EZ
« Reply #26 on: November 25, 2017, 11:50:52 PM »
 Well the chimney will go all the way up or I would do something like that
Outdoor wood furnace
Started by JRC on Sawmills and Milling
Last post October 31, 2004, 04:40:55 PM
by Mark M
DIY Outdoor Wood Furnace
Started by clif on Alternative methods and solutions
Last post October 19, 2007, 02:22:30 AM
by beenthere
Which outdoor wood furnace?
Started by ohsoloco on General Board
Last post May 11, 2003, 03:15:15 PM
by Furby
Started by dewwood on General Board
Last post June 17, 2003, 09:39:19 PM
by dail_h
