Arborwear
Author Topic: License Plates For LT28  (Read 1341 times)
Online AlpineCutter
« on: October 31, 2017, 07:40:00 PM »
I am wondering what everyone has done for license plates on their portable mills. I understand every state will be different but here in Colorado they aren't going to let me register it as a trailer so i have to register it as equipment which is going to cost around $300 for plates.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: License Plates For LT28
« Reply #1 on: October 31, 2017, 08:28:04 PM »
Ouch, mine is considered farm equipment (same as a hay bailer) and has no license plate.
Online AlpineCutter
« Reply #2 on: October 31, 2017, 08:32:07 PM »
I thought it should be something like that. I am going to the county office again tomorrow and see if i can make that happen too.
Offline crowhill
« Reply #3 on: October 31, 2017, 08:35:10 PM »
I was told by Motor Vehicles the same as MM, considered farm equipment no need for registration, but that was 15 years ago.
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws, 26 chickens and Hereford beef cattle.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: October 31, 2017, 09:14:59 PM »
Same as Lynn said!
No plate required, because IT IS NOT a trailer, it is a piece of equipment!
~Chuck~
I LOVE MY SAWMILL
Offline PAmizerman
« Reply #5 on: October 31, 2017, 09:18:57 PM »
I was told my mill is considered what they called an implemant of husbandry. Same as like a wood splitter. As long as you don't haul anything on it it's not considered a trailer. At least that's what I was told  PA does. Not sure for you're state but I'd ask about implemants of husbandry.
Traverse 6035 telehandler and a lot of back breaking work!!
Online AlpineCutter
« Reply #6 on: October 31, 2017, 09:24:43 PM »
Thanks for the replies guys! I was also wondering why i would need plates when i see log splitters all the time that dont have plates.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #7 on: October 31, 2017, 09:53:31 PM »
   My state does not require a license for my mill - they consider it a piece of mobile equipment. I do know when I bought my mill WM provided me a separate title to the trailer and to the mill just in case I ever had to get a license. Good luck finding the best option in your state.
Offline irvi00
« Reply #8 on: October 31, 2017, 10:06:16 PM »
Slap a orange triangle on it and claim farm equipment. Easier to beg forgiveness.
Online Darrel
  • Never throw an unopened log on the burn pile.
« Reply #9 on: October 31, 2017, 10:21:29 PM »
Oregon told me that my mill is a fixed weight trailer and wanted to charge me $75 for plates.  I told them if my fixed weight trailer needed plates than so did all the other fixed weight trailers that people use for hey balers. They said I had a point that just might stand up in court but in the meantime I needed to buy plates. I decided to take my chance in court if I ever get stopped. I've been followed by more than one state trooper and never got stopped so I think I did the right thing.
1992 LT40HD
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: October 31, 2017, 10:29:34 PM »
When I am traveling mine looks like this.
An older picture before I made the rectangular sign.
Offline ljohnsaw
« Reply #11 on: October 31, 2017, 10:37:13 PM »
The problem with a triangle farm equipment "plate" is you are limited to how fast you can go, IIRC, like 15 or 20 mph.  That is a sign of an always slow moving vehicle, like a tractor.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #12 on: October 31, 2017, 10:55:18 PM »
Although considered "agricultural" for property tax purposes (exempt), Kansas does require tags on sawmills.  If you fall under USDOT, it also requires a permanent tag on a sawmill (I am considered an interstate, private, motor carrier subject to USDOT regulation).  What other states require is anecdotal, you need to verify what Colorado requires.
It takes a bit more work but, if you are under an exemption, it is a good idea to make a photocopy of the regulatory exemption and carry it with you.  If you travel in more than one state, as I do, it is a good idea to carry that type of information with you for reciprocity considerations.  If it is something uncommon, as sawmills on the roadway seem to be, some officers/deputies/troopers will write a citation (especially you appear deceptive or feign ignorance) and let the prosecutor or judge figure it out - which costs you time and money to challenge.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Online WV Sawmiller
« Reply #13 on: November 01, 2017, 07:34:59 AM »
   ljohnsaw has same observation I do. I am very certain the triangle sets you up for a ticket if driving anywhere close to highway speeds. Tom is right - doesn't matter what other states require or allow. You have to comply with yours.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #14 on: November 01, 2017, 07:41:43 AM »
Had a friend of mine get a ticket for driving too fast while displaying a slow moving sign (wasn't speeding).
I don't know how MO handles it as neither of mine have wheels.  I would be okay with the $50 permanent plate.  It's the sales tax they charge to get the title to get the tag that would bite.
Offline Chuck White
« Reply #15 on: November 01, 2017, 08:00:55 AM »
I've had County Sherriff Deputy tell me that the max speed in NY with a SMV sign posted is 25MPH.
~Chuck~
I LOVE MY SAWMILL
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #16 on: November 01, 2017, 09:41:30 AM »
     In Florida, the DMV says if it's towed behind a vehicle it's a trailer and needs a tag.  Trailer tags are rated/priced by weight.  An LT50 makes for a pretty heavy "trailer."
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline AlaskaLes
  • Livin the dream!
« Reply #17 on: November 01, 2017, 02:13:04 PM »
Alaska DMV told me that our 185CFM Sullair compressor was in the Mobile Equipment category.
I'd never heard of that before but was all too happy to NOT pay for more licensing and fees.
Sawmill would be in this same category, but it's mounted semi-permanent now.
You can see Mt McKinley from our backyard...Up Close!!
Mighty Mite MK 4B, full-hyd, diesel bandmill
Kubota 4wd 3650GST w/FEL; Forks;
3pt Log Arm& Log trailer
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
Robar RC-50 50BMG-just in case the trees get out of line
Offline ljohnsaw
« Reply #18 on: November 01, 2017, 11:08:18 PM »
I had a CHP officer tell me if it has wheels that touch the road in California, it needs plate...
John Sawicky
Offline Gearbox
« Reply #19 on: November 02, 2017, 10:26:46 AM »
Don't tell MN that I can't pull my grain wagon at 40 MPH . I use it to deliver wood it the buyer has a tractor to dump it .
Vanity License Plates
Started by DR_Buck on General Board
Last post December 30, 2007, 05:28:38 PM
by isawlogs
do I need license plates on a knuckleboom mounted on a trailer?
Started by Nemologger on Forestry and Logging
Last post June 13, 2014, 01:33:05 PM
by BargeMonkey
Top plates.
Started by Dave Shepard on Timber Framing/Log construction
Last post June 04, 2015, 01:32:20 AM
by Chilterns
Skid plates
Started by HiTech on Forestry and Logging
Last post January 02, 2013, 12:37:32 AM
by HiTech
