TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: MS 250 carb issue  (Read 354 times)
Offline azmtnman
MS 250 carb issue
« on: November 01, 2017, 03:42:20 PM »
My MS 250 has about 5 hours on it (if that!) It quit running right and I put it aside a couple years ago and just got it back out to try to repair.
It would run fine for a few minutes then act like it was running out of gas so I changed the pump diaphragm. It's not as bad now but after it's warm, it won't run mid rpm--which includes getting through mid rpm to get high rpm. Once at high rpm, it runs and cuts fine as long as you keep it there.
What am I missing?
1983 LT 30, 1954 Ford NAA, 2006 Polaris 500 EFI, '03 Dodge D2500 Cummins powered 4X4 long-bed crew cab, Cummins powered '88 Chevy R30, Stihl MS250, MS311 and MS661--I cut trees for my boss who was a Jewish carpenter!
Offline ladylake
Re: MS 250 carb issue
« Reply #1 on: November 02, 2017, 05:06:26 PM »
 If the low adjuster is too lean or the low circuit is clogged it will act like that.  Steve
Offline azmtnman
« Reply #2 on: November 02, 2017, 11:04:26 PM »
So it has like an idle jet?
Offline dougand3
« Reply #3 on: November 03, 2017, 12:38:50 PM »
Fully adjustable MS250 carbs have H, L and LA(Idle) screws. Some have fixed jets and can't adjust. Fully adjustable are available online for ~$10.
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
2004 honda 350 es rancher, carb issue
Started by drobertson on Chainsaws
Last post July 12, 2013, 12:57:46 PM
by BARPINCHER
Stihl HT 131 Pole Saw Carb Adjustment issue.
Started by JOE.G on Chainsaws
Last post August 16, 2012, 02:09:12 PM
by Al_Smith
New Stihl carb or Warblo carb?
Started by ihookem on Chainsaws
Last post April 24, 2015, 07:45:06 PM
by SawTroll
old 08s carb
Started by AnthonyBowkett on Chainsaws
Last post August 12, 2014, 12:42:34 AM
by sablatnic
