Arborwear
Author Topic: shake or stress?  (Read 1006 times)
Offline alanh
shake or stress?
« on: November 04, 2017, 10:40:56 AM »
I got this pine this week, the top of the tree had blown off in last weeks storm, these were still standing. I`m not sure if the cracking is from shake, stress, or both, still looks like a lot of salvageable lumber to me...
Offline thecfarm
Re: shake or stress?
« Reply #1 on: November 04, 2017, 11:49:26 AM »
Not home so can't look up the latin name,but white pine?
If so I kinda doubt shake. I have sold logs and cut probably the same amount for firewood,never seen shake in a white pine like that.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: November 04, 2017, 12:18:40 PM »
The tree may have split when it was felled!
~Chuck~
I LOVE MY SAWMILL
Offline alanh
« Reply #3 on: November 04, 2017, 12:23:02 PM »
It is white pine, I wasn`t sure if shake affected it, could be from the wind or dropping it..
Offline loganworks2
« Reply #4 on: November 04, 2017, 02:16:11 PM »
From the first picture it looks like it must have been a standing dead tree. If it was it was most likely damage from felling the tree.
Offline Ianab
« Reply #5 on: November 04, 2017, 04:00:03 PM »
I think it's mostly a stress crack from the tree falling. Wood in a dead tree is more brittle and more likely to crack when it hits the ground.
But you can also see how the crack has followed a semi-circle section of growth rings, and those rings have a different colour. That's more indicative of "shake". Maybe "something" happened early in the trees history. Fire / lightning strike etc. Didn't kill the tree, but weakened that growth ring. The tree recovered and kept growing normally, but left that weak ring.
That's my theory anyway.  :D
And yes if you can saw around the crack, the rest of the wood should be OK.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #6 on: November 04, 2017, 05:06:50 PM »
I've seen Pondarosa and lodgepole pine do that but only when standing dead.
1992 LT40HD
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #7 on: November 05, 2017, 04:56:54 AM »
I have seen shake in W Pine a time or two.
That's shake and when the tree was cut it landed on something to crack it , or someone pulling the tree out bent the thing too far around a bump tree.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
    • A&P Saw mill LLC
« Reply #8 on: November 07, 2017, 06:33:28 PM »
Had one today.
Sawing since 1987
Shake, ring shake, wind shake in timber
Started by pine on Sawmills and Milling
Last post June 13, 2014, 02:08:45 PM
by Ron Wenrich
Shake Rat
Started by Gilman on Sawmills and Milling
Last post October 20, 2004, 10:56:07 PM
by Gilman
shake
Started by laffs on Ask The Forester
Last post October 28, 2010, 06:38:45 PM
by laffs
Is this shake
Started by brdmkr on Sawmills and Milling
Last post May 04, 2007, 04:48:58 PM
by inspectorwoody
