Arborwear
Author Topic: Building a New Kiln - SIPs anyone?  (Read 1140 times)
Offline PA_Walnut
« on: November 05, 2017, 07:14:05 AM »
Apologies if this has been covered, but my 4000BF (2HP) dehumidifier kiln has arrived, so planning my build asap.
Was thinking about getting some SIPs to drop in to expedite my build and give me tighter insulation.
Anyone down this path before me? Any considerations? Thx
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline GeneWengert-WoodDoc
Re: Building a New Kiln - SIPs anyone?
« Reply #1 on: November 05, 2017, 08:13:24 AM »
An SIP would be fine.  Make sure it will withstand 150 F, that it insulates as much as or more than a 2x8 insulated wall, that it is impervious to moisture- -vapor and liquid, and that it is worth the extra cost compared to DIY.  Keeping joints tight can be an issue.
SIP = structural insulated panel
Offline jtcweb
« Reply #2 on: November 28, 2017, 02:14:34 PM »
My house is built from SIPs.  There is no problem with the joints being tight as a 2x6 (assuming 6" panel) gets glued and screwed in each joint.  They have almost no air infiltration so make sure you plan for any airflow you need.  However it is fairly easy to cut another (or bigger) hole if you need airflow.  I don't know how well the OSB will hold up over time if you have periods of high RH.  You might want to cover it with some kind of sealer.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: November 28, 2017, 05:22:54 PM »
Current SIPS might be better than the building i just looked at, it was built in 1993 and the owner didnt flash some corners.  This was basically foam between two sheets of tin like a metal door.  All exposed foam was badly degraded from sun.  Im sure it'd have been fine if flashed properly.  Just something to keep in mind if you use them.  Current stuff might be totally different.
Revelation 3:20
Offline PA_Walnut
« Reply #4 on: November 28, 2017, 06:09:20 PM »
Thanks. I think I'm gonna do conventional methods. The SIPS seem good for large projects, but not sure the cost:benefit ratio is there for mine.
Offline Blackhawk1
  • Living the dream
    • Blackhawk Millworks
« Reply #5 on: December 06, 2017, 11:05:06 AM »
My home is a SIP panel home and I feel SIP is a good way to go. I have two friends with SIP panel homes and they have no problems. SIP's are available clad in aluminum, this could be an option instead of OSB, as for heat they should handle it as the SIPs are designed for attic use and attics will get over 150 and the side facing out will be over 150 here in TX. Just my two cents. Going back I wish I had made my kiln from SIPs, it is wood and steel purlin with spray insulation.
 with
Doug Caroselli
512-738-1770
Offline C_Miller
  • yes, we have trees in New York
« Reply #6 on: January 21, 2018, 08:28:58 AM »
Using SIP's will get you drying sooner and when the electric goes up will save you money there. There will be no heat transfer through studs and the conventional will change shape as the studs continue to dry.
CJM
« Reply #7 on: January 21, 2018, 05:12:40 PM »
Be careful that the panels are designed for kiln temperatures and humidities.  The joints also must accommodate the wide temperature changes.  With the sun shining, non-white color so solar is absorbed, and the internal kiln temperature, the panel can get really hot.
Offline K-Guy
    • http://www.nyle.com/
« Reply #8 on: January 22, 2018, 08:48:41 AM »
SIPS are fine as long as you follow Gene's advice. I have a customer who built his kiln with them 10 years ago and it's still in great shape. :)
Offline Brad_bb
    • My timberframe blog
« Reply #9 on: February 04, 2018, 03:11:45 PM »
This is an interesting concept.  I know a sips installer who usually has scrap cut offs from each job. You could spline those pieces together to make bigger wall panels.  I'm going to talk to him about it.
Offline longtime lurker
« Reply #10 on: February 04, 2018, 08:54:55 PM »
Gotta get the I right.
SIP's were my first choice for a kiln chamber but all the prefab panels here were based on an open cell styrene type foam. You really want closed cell foam for kiln panels.
As always the devil is in the details.
SIPS R factor and building codes.
Started by Tremel on Timber Framing/Log construction
Last post March 02, 2008, 08:06:37 PM
by Tremel
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
Building a Kiln Part 4 Building Construction Updated video..
Started by 123maxbars on Drying and Processing
Last post August 08, 2017, 08:20:41 PM
by 123maxbars
Building a kiln
Started by Cypress Man on Drying and Processing
Last post December 15, 2007, 11:28:24 PM
by scsmith42
