Arborwear
Author Topic: Identify what model heatmaster?  (Read 242 times)
Offline Justify008
  • I'm young but not stupid
« on: November 06, 2017, 07:52:58 AM »
Can anyone identify this heat master boiler by the picture. I'm going to look at it in a couple days. Trying to figure out the weight?  Asked the owner he hasn't gotten back to me yet. It has a water leak by the door are these known for leaking in a certain spot? Think it's rotted or just cracked?
Offline LAZERDAN
Re: Identify what model heatmaster?
« Reply #1 on: November 06, 2017, 08:53:56 AM »
Yep:  That's a 434,  If the leak is by the door, the water had boiled and caused a hole to erode.  I welded up mine 5 yrs ago.  No problem with leaks or cracks, built very well.  Any good welder can repair.  Beware the door area is double walled, my leak was in the inner wall.       That burner, is not a boiler, it only heats the water, but in this case it was boiling, most likely bad door seal or heavy loading by the door.     Lazerdan
Offline Justify008
« Reply #2 on: November 06, 2017, 01:11:38 PM »
So it's a wood master? The guy advertised it as heat master. Any idea on weight? I'm going to try calling woodmaster see if they have old specs. Or an owners manual.
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #3 on: November 07, 2017, 05:34:55 AM »
Definitely a Woodmaster. 1/4" Mild steel (heavy), my dad burned one for quite a few years. Door jamb got thin from condensation. Check that and pull the roof and check for corrosion around the chimney, it can get wet there if the silicone leaks. Scrape the inside of the firebox at the ash line. You mentioned a leak near the door, a crack on the door jamb on the outside is easily welded, a thin door jamb is more involved..
All in all a simple solid unit. Not saying you'll see the things I mentioned, just things I've seen a few times.
 Just check it out carefully.
HeatMaster dealer support in VA.
GS100.
Offline Justify008
« Reply #4 on: November 08, 2017, 08:42:32 PM »
Well She's home. 200 miles and $300 dollars later. Seems to be in okay condition. I'm the third owner. The first owner welded well casing for the chimney so that must of rusted out.
Above the door where the leak is supposedly coming from only clean spot inside
Help to identify stihl model
Started by MakitaCS on Chainsaws
Last post November 26, 2008, 03:54:26 AM
by joe_indi
OWB P&M vs HeatMaster
Started by OWBnoob on Firewood and Wood Heating
Last post August 17, 2017, 10:11:16 PM
by mf40diesel
Heatmaster 5000 finally in use
Started by 1woodguy on Firewood and Wood Heating
Last post December 13, 2013, 09:19:22 PM
by 1woodguy
Central Boiler vs Heatmaster
Started by Crhall on Firewood and Wood Heating
Last post March 26, 2015, 10:31:04 PM
by sizzler
