EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Input on wood splitter build please  (Read 277 times)
Offline scully
  • Orange Mills Matter
« on: November 06, 2017, 09:44:35 AM »
I wasn't sure what to put this under , anyway I am going to build a wood splitter using one I have that was poorly made I.E. home built . My question is what would be a good hydro pump ,size etc. ? I will be using a 24 h.p. Onan to power it . I will also have a loader on it . I have little knowledge of pump sizing etc. any help is appreciated . This will be a very heavy duty splitter .  I have all the other parts I need .
I bleed orange  .
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: Input on wood splitter build please
« Reply #1 on: November 06, 2017, 10:32:17 AM »
When I built mine I went to a local hydraulic shop, gave them hp, cylinder size . They helped with pump and valve size.
If it is true that we learn from our mistakes, I must be Brilliant!
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
Offline Gearbox
« Reply #3 on: November 06, 2017, 06:09:46 PM »
with that kind of power you are unlimited on 2 stage pumps 22 gpm 26 gpm that will handle it  . You will need a very large oil tank . 1 gal. of tank for each gal of flow . I run 2500 psi on a 4 X 24 in. cylinder and it will test your welds .
Offline North River Energy
« Reply #4 on: November 06, 2017, 09:32:06 PM »
What is the flow capacity of your valves and cylinder ports?
My log splitter project - Input needed
Started by bmcdowell40 on Firewood and Wood Heating
Last post March 13, 2014, 05:49:19 PM
by Cguignard
Log splitter build
Started by 6sunset6 on Firewood and Wood Heating
Last post February 24, 2012, 10:08:11 PM
by 6sunset6
new splitter build
Started by stumpjumper83 on Firewood and Wood Heating
Last post November 19, 2015, 06:27:23 PM
by Al_Smith
Log splitter build
Started by Andrewd2006 on Firewood and Wood Heating
Last post February 11, 2016, 08:16:36 AM
by Northern Logger
