Arborwear
Author Topic: Olive tree removal with saving the wood  (Read 250 times)
Offline Matchstick
  • Member*
« on: November 06, 2017, 12:42:54 PM »
I have a 3 foot diameter (stump then branches out at 1+  foot limbs) olive tree that i am removing and i want to save the wood. I have removed branches in the past and found it turns to iron in no time. Should I slab it crossgrain or  cut 2-3 foot sections and slab those? Cut and slow dry or  leave as whole since it will be months till final cut? Tree is 1500 miles from home so final storage will be a month after cut.
Hate for all that wood to end in a fireplace.
Thanks for any insight.  :snowball:
Offline Jemclimber
Re: Olive tree removal with saving the wood
« Reply #1 on: November 08, 2017, 06:58:59 AM »
Welcome Matchstick,
 What are you going to use this for, turning? Or small flat work projects?  Leave it as long as possible and cut it into boards or slabs the thickness you think you'll be using.  Make sure to get the center(pith) cut out and seal the ends with anchorseal(an emulsified wax coating) or use melted paraffin. Leaving it as long as possible will help reduce the loss to end checking while it dries if the wax doesn't completely stop it.
Tell us what you want to do with this and we can better help you.
lt15
Offline PA_Walnut
« Reply #2 on: November 08, 2017, 07:03:45 AM »
As stated, get the ends sealed ASAP with AnchorSeal. (not paint, which doesn't seal as well).
Curious where you are located with olive wood?  ???
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Olive wood
Started by theorm on Wanted
Last post December 17, 2007, 12:47:27 AM
by theorm
question
OLIVE WOOD- how to get it to not crack
Started by Guner Tautrim on Drying and Processing
Last post December 13, 2012, 11:53:33 PM
by GeneWengert-WoodDoc
Where can I find some Olive Wood
Started by kilndry on Drying and Processing
Last post June 29, 2006, 07:58:17 AM
by kilndry
question
suggestions in milling olive wood
Started by djcoop on Sawmills and Milling
Last post April 19, 2011, 10:50:45 PM
by Tom
