Arborwear
Author Topic: difficult pull cord start on Stihl 256  (Read 698 times)
Offline doctorb
  • Unofficial Team Physician
« on: November 06, 2017, 04:23:23 PM »
Forgive me, I don't spend much time on the Chainsaw board, so this may have been addressed previously. I have a problem with my Stihl 256 and I can find no answer here through Searching.
When I go to pull the cord, it pulls out for about 6-8 inches and then stops hard, almost like it's pulling back.  Hurts my hand.  I can sometimes pull through these sudden jerky stops to pull it out another 6-8 inches, where it stops hard again.  The stops seem to happen every 6-8 inches of cord pull.  Eventually, the stops grow less abrupt, I can pull the cord fully and the saw starts and runs great.  This is really annoying as it's now hard to use the saw, put it down for a bit, and then quickly restart it a minute of two later.
I hope I have explained it well enough for one of you experts to let me know what's up.
Thanks for your help.
Online ladylake
Re: difficult pull cord start on Stihl 256
« Reply #1 on: November 06, 2017, 04:35:11 PM »
 Never heard of a Stihl 256,,  Take the recoil off and inspect,  sounds like the rope might be getting pinched every round, maybe needs a new rope or the spool is wore out or cracked.  Steve
Offline Gearbox
« Reply #2 on: November 06, 2017, 05:55:58 PM »
Doc I have had that happen with a 55 rancher . Turned out to be just dirt buildup under the cover . just clean it up and give it a little lube .
Offline joe_indi
  • The older I get the more I learn
« Reply #3 on: November 07, 2017, 04:02:07 AM »
Carbon buildup on the piston and cylinder could be a possibility.(Increase in compression)
Play between the connecting rod and piston could be another possibility (crank moves to ignition point while piston is still moving up)
Try flooding the engine before you try starting. Do you still get the jerks? If  there are no jerks when the engine is flooded it could be the con rod play.
Try it with the switch in Off, if there are no jerks, it confirms the conrod play.
A temporary fix (sometimes) is to increase the electrode gap of the spark plug
Offline doctorb
« Reply #4 on: November 07, 2017, 02:22:29 PM »
Thanks.  I'll give those things a try.  I'll also recheck the model of my Stihl.  I'm sure I got that wrong!
It's interesting, but it seems to happen after I have run the saw, although it doesn't take much use for this to occur.  Much less trouble starting when it's cold.
Offline Al_Smith
« Reply #5 on: November 08, 2017, 05:55:40 AM »
Thought of something since the mention of heat was added to the conversation .I know nothing about the model mentioned but it could have a self advancing ignition coil .The 042 and 048 Stihls did and occasionally one would fail to advance which limited the saws power and speed,slower .
Now just the opposite might be happening if that's the coil design .I had a coil fail on full advance on a Briggs 18 HP twin engine .Even with electric start you could turn it over until it cooled off .
Offline kenskip1
  • Stihl Looking for the fountain of middle age.
« Reply #6 on: November 08, 2017, 05:26:27 PM »
From what I am hearing it sounds like it could be hydrolocking.Mix from the carburetor is leaking into the cylinder causing the problem mentioned.Pull the spark plug the next time this occurs, then pull the rope.
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
Offline drobertson
« Reply #7 on: November 10, 2017, 11:52:10 AM »
Like others never heard of this model, but to the point, I had a poulan do the same, it was in the reel itself,
sounds like an easy one once found,
Offline doctorb
« Reply #8 on: December 02, 2017, 03:26:12 PM »
It's a 260
Got er fixed.  Thanks
Offline sawguy21
« Reply #9 on: December 02, 2017, 03:30:11 PM »
Good. What was the problem?
Offline PartTimeJack
« Reply #10 on: December 02, 2017, 07:37:46 PM »
Had the same problem on my 250, the rope was binding on, and ended up tearing the rope. Replacing it fixed it.
A hickory stick, and a cherry twist for me.
Just a Farmer learnin to be a Jack.
Pull start cord not going back in...
Started by sigidi on Chainsaws
Last post January 24, 2006, 08:29:58 AM
by Minnesota_boy
Pull cord keeps shearing off (Stihl 038 Mag)
Started by damien on Chainsaws
Last post July 16, 2014, 01:16:33 PM
by joe_indi
Stihl pull cord wont retract
Started by moose207 on Chainsaws
Last post November 15, 2017, 06:50:55 AM
by moose207
Stihl 031 skipping during pull start
Started by kmorgan on Chainsaws
Last post November 24, 2013, 09:27:56 PM
by stihl for life
