KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: JD 110 Hyd Pump crashed  (Read 417 times)
Offline Qweaver
  • The cabin is done and we love it
« on: November 08, 2017, 01:16:48 PM »
Front loader quit working and big grating noise started coming from the front of the tractor.  I shut it down immediately and I'm guessing the Hyd pump is gone.  I don't even know where it's located.  I replaced one on my old Ford and it was easy.   Any hints where I should start looking?  I guess it's time to buy a manual. There go the profits from the $1000 saw job I just finished.
Quinton
Offline DanG
Re: JD 110 Hyd Pump crashed
« Reply #1 on: November 08, 2017, 01:29:36 PM »
I had a similar incident with my Cat backhoe. It turned out to be the coupling between the engine and the pump. The screw that clamps the coupling around the shaft had come loose and it ground all the splines out of the coupling.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: November 08, 2017, 03:49:59 PM »
You've mentored having problems with the coupling before on this tractor. Isn't the pump run off the front of the crank?
Offline Qweaver
« Reply #3 on: November 08, 2017, 04:03:30 PM »
Yeah DanG, I had that happen on my old Ford backhoe too.  I hope it is something like that this time also.  But I will not be able to work on it until Monday.  My Kubota  will see me thru until then but I can't lift the big logs with it.  I wish I had a workshop manual.  It might save me a lot of time if I knew exactly how to do it.
Quinton
Offline Qweaver
« Reply #4 on: November 08, 2017, 05:04:48 PM »
How in the world  did you remember that Dave.  I had forgotten it.   This is the second time.  It is a sintered splined hub  and probably designed as the weak spot to fail before the pump splines.  $76  and had to be ordered.  I sure hope the pump splines are OK.  I remember that it was not an easy job to replace it.
Offline Qweaver
« Reply #5 on: November 25, 2017, 09:26:54 PM »
My diesel mechanic cousin showed me the easy way to do this repair and it went very quick and well.  I put a spare on the shelf just in case it happens again.
System Crashed
Started by LeeB on Technical Support Topics
Last post March 01, 2008, 07:14:21 PM
by sprucebunny
Diesel Primary pump from tank to injector pump
Started by Ironwood on General Board
Last post January 25, 2005, 08:12:11 PM
by Ironwood
How big should my pump be?
Started by CX3 on Forestry and Logging
Last post September 25, 2010, 08:28:53 PM
by madmari
thumbup
Hyd. Pump, Down and Out. All better now
Started by Kevin_H. on General Board
Last post June 25, 2005, 09:45:58 PM
by Minnesota_boy
