Arborwear
Author Topic: Nyle L53 Kiln Start Up  (Read 5281 times)
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Nyle L53 Kiln Start Up
« Reply #20 on: December 03, 2017, 07:24:59 AM »
Yes.
Offline GeneWengert-WoodDoc
« Reply #21 on: December 03, 2017, 06:16:05 PM »
Yes, the wood should dry and moisture leaving the wood will have to get out as liquid in a DH kiln.  If the vent runs, some moisture leaves as vapor.
Offline maderahardwoods
  • California Sawyer
    • Madera Hardwoods
« Reply #22 on: December 07, 2017, 04:07:45 PM »
Update:
Moisture content 13.5-18%, pulling less than 1 gallon  a day.
DB 118-120 (its been cold)
WB: 86-88
-Marco
  • California Sawyer
    • Madera Hardwoods
« Reply #23 on: December 11, 2017, 09:43:08 AM »
So I went 24hrs without pulling a drop of water so I decided to try another case hardening treatment as recommended by Nyle. But this time I dumped about 3 gallons of water on the floor and sprayed the slabs with water directly and set the kiln to 140F.  By Saturday 3PM I was in the high 130s and by 5PM I was at 140F.
I let the kiln sit at 140F DB (106WB) for about 24hrs, at the 24 hr mark I opened up the doors and brought the temperature down to 120F and the WB dropped back down to 85, I then restarted the compressor.
I checked the unit this morning and not a drop has been collected in the bucket.  I am assuming a lot of the moist air escaped with the when the high temp van kicked on as well as opening the doors.
Does anyone have some experience the can share regarding kiln drying claro walnut?
I will take some moisture readings this afternoon.
Thanks,
Marco
Offline WDH
« Reply #24 on: December 11, 2017, 04:59:53 PM »
Sounds like that you are there.
  • California Sawyer
    • Madera Hardwoods
« Reply #25 on: December 11, 2017, 10:56:49 PM »
So I took some readings after work.
The shorter log is at: 13.3% left side, 16.4% right side
The longer log is at: 17.4% left side, 8.8% right side
WDH, do you think I am drier than I think? Possibly the pinless meter is reading inaccurately?
I am considering purchasing the Delmhorst J2000x kit.
Thanks,
Marco
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #26 on: December 12, 2017, 12:33:02 AM »
Sounds normal if it was stalled black walnut.  It could also be the meter.
If the wood is at 17% you should be able to feel it as wet simply by touching it, as well as by weight.  It will also look noticeably darker due to the moisture.  Conversely, when wood is at 8% or lower, it is noticeably dry to the touch.
I never liked pinless meters for rough sawn lumber.  Delhmorst makes a good unit.
Considering the value of walnut, when in doubt, use the oven dry method. It's dead on, and quite fast measure the weight of a sample board of every day.   Even if you get a meter, always check it by the oven dry method occasionally.
It's hard to devise a strategy unless the moisture content is accuratly known.
I like 150F for stalled wood, no extra water on the floor, zero compressor.  Closed vents.  Let it stand at temp for a day or two.  Open the door and see if the wood is "sweating".  When you open the door, you will get hit with a blast of hot humid air, and will see a noticeable moisture sheen on the surface of the boards that flashes off instantly.  The moisture has come from the core of the wood and it will be drier.
Again, this is the strategy for me on stalled black walnut.
HobbyHardwoodAlabama.com
Offline WDH
« Reply #27 on: December 12, 2017, 07:16:51 AM »
Make sure that your compressor has not tripped from too high temp, over about 133 degrees.  Take the side panel off and press the little green button to re-set.
  • California Sawyer
    • Madera Hardwoods
« Reply #28 on: December 12, 2017, 10:22:14 AM »
Last night I switched the compressor to "off" and decided to just let the wood sit at 120F overnight to see if the WB would come back up.
When I get home tonight I will check to make sure the compressor has not tripped and see if the wood is "sweating" at all from being at 120F overnight with no compressor.
If not, I will bump the temp to max (which I think is 140F) and let it sit for a night or two and report back.
I am considering adding some box fans behind the stack (between L53 and lumber pile) to help pull the air through the stack.  I may just bite the bullet and buy the J2000X, it seems to be held in high regard by Nyle and the FF.  Looks like they even offer some probes to avoid opening the doors to check the moisture content.
Thanks,
Marco
  • California Sawyer
    • Madera Hardwoods
« Reply #29 on: December 12, 2017, 04:31:09 PM »
The J2000X happened to go on sale this afternoon on testequipmentdepot.com, price dropped from $530 to $387 so I decided to jump on the deal, should have it in about a week or two.
« Reply #30 on: December 12, 2017, 09:17:07 PM »
As WDH says, the safety trip should be checked.  Or if you can get to it, cycle the compressor on and slide the front filter up and feel the coil, it should be cold.
The L53 should get to 150F no problem, for sterilization.
Never run the compressor over 120F.
I used a box fan to augment airflow.  A better alternative is to cut an additional vent opening in the bottom of the unit and fit in a range hood filter.  If you do a search you will find some pics of the mod. It will blow out the dead space in the lower center of the stack.
Offline WDH
« Reply #31 on: December 12, 2017, 09:23:13 PM »
I run double box fans at the back of the stack between the lumber and the back wall.  I cut the additional intake into the bottom of the unit like YH recommends.  Really helps even out the drying and it also increased the amount of water removal just a bit too.
  • California Sawyer
    • Madera Hardwoods
« Reply #32 on: December 12, 2017, 11:08:36 PM »
So I opened up the side of the dehumidification unit and pressed the reset, didn't feel any type of mechanical "click".  Moisture content is almost exactly the same as the day before.
I switched on the compressor, if I do not pull any water by morning I'll switch the compressor off and let the unit sit at 150F for 24hrs and check for water condensing on the surface.
I will definitely make that modification to the bottom of the unit once the load is out and can pull the unit out, I will try and add some fans this weekend as well.
How cold should the coil be? I feel like I have touched it in the past and it wasn't all that cold.
Thanks for the advice gentlemen!
Offline WDH
« Reply #33 on: December 13, 2017, 07:39:49 AM »
Do this test.  Make sure that the dry bulb is over 80.  Set the wet bulb at 75.  Turn on the unit, compressor, and the heater.  Watch the temps while standeing by the controller.  As soon as the wet bulb temp hits 2 above the wet bulb set point, in this case 77, begin timing using the stopwatch on your phone or use a watch.  After 5 minutes, you should hear a noticeable "click" which indicates the the compressor has kicked on.  This way, you know that your compressor is up and running.  You have to reach 2 degrees above the wet bulb set-point for the compressor to be activated, then there is a 5 minute delay before the compressor will come on.
On the panel, if you look at the compressor, it might say "ON" on the panel.  That does not mean that the compressor is actually running.  If means that the conditions in the kiln are such that if you had the switch turned on, then the compressor would kick on in 5 minutes.  It just indicates that the system is ready.  This confused me for a while as I originally thought that "ON" on the display meant that the compressor was actually running.  When I first started running my L53, I did not know about the over-temp shut off on the compressor.  That was not in my manual.  Not understanding that, I ran the compressor while the temps climbed over 130 and it tripped the compressor.  But, I did not know that.  I thought that it was running because the display said "ON".  I could not get any water and I was frustrated.  That is when I took the side panel off to check all the wiring and connections to see if anything was loose and I say that little green button.  Not knowing exactly what I was doing, I mashed the button (pressed the button if you are a Yankee  ;D) and no click, no nothing.  Went back to the panel and turned the unit back on.  Nothing.  This was after 3 or 4 days of frustration trying to figure out what was wrong and after 3 or 4 calls with Nyle tech support.  Sat there by the control panel trying to figure out what to do next (which included sending the unit back to Nyle) and about 5 minutes had gone by and I heard a noticeable "click" from the control panel, and voila, I got water.
On the re-set button, there is no type of "click".  If you push it all the way in, it will re-set the compressor though.  You need to make sure that your compressor is running.
  • California Sawyer
    • Madera Hardwoods
« Reply #34 on: December 13, 2017, 10:23:19 AM »
WDH thank you for that reply.
So last night I decided to crawl into the kiln and see if the coil had any water condensing on it.  I opened the filter and could see a few drops dripping into the catch tray, I touched the coil and it was cool to the touch, but definitely not cold. I may borrow the thermal imaging camera from work and measure some temps in the kiln.
While behind the stack I felt that the airflow was stagnant, I remembered that I had one box fan in my garage and decided to place it between the stack and L53. I think I will pick up two box fans this afternoon and add them to each side of the stack to help the airflow between the slabs.
Morning Update (Dec 13th, 2017): I swung by before work and the DB was 120 and WB was 85, I took a look in the collection bucket and I had about 1 cup of water collected, not much for 9hrs running.  I am hoping the fans will help with the water pull.
« Reply #35 on: December 13, 2017, 11:16:49 AM »
Sounds like the system is working properly.  There is a high and low pressure switch in the refrigeration system.  If the compressor is operating properly, the copper line from the compressor going to the bulkhead should be cold, much like an automotive air conditioner line.  There may even be frost on it, but when properly charged, the frost should line stop at the compressor bulkhead.  There should be no frost on the coil unless the system is low of freon.
It's very useful to listen to the sound of the compressor, and know it, as that will be a very useful diagnostic tool for you in the the future.
The controller only calls for compressor, but is open loop, so doesn't get feedback as to what is actually happening.  If there is water condensing and dropping into the catch rail, then it is working properly.  With this particular compressor, it is almost impossible to tell of it is fully charged with a set of refrigeration pressure gauges.  In fact, to recharge the system, the charge has to be weighed in to be accurate.
You can very easily bypass the high and low pressure switch by using a small jumper at the terminal block in the DH unit.  I've had to do this several times for trouble shooting purposes.  The electrical schematics should be in your manual.
  • California Sawyer
    • Madera Hardwoods
« Reply #36 on: December 13, 2017, 04:31:56 PM »
Thank you Yellowhammer.
With MC under 20% for 700-900 bd ft, how much water is typically collected in a 24hr cycle? I understand that the MC of the timber is the ultimate indicator of a healthy kiln, but I feel that the water collection bucket is a sanity check.
I felt the surface of the boards and they definitely felt dry (and obviously warm).  It did not have that cool feeling a freshly cut slab or even an air drying slab has from the internal moisture.
Offline WDH
« Reply #37 on: December 13, 2017, 08:35:25 PM »
With a 35 wet bulb depression, you have very low humidity in the kiln.  With only that small amount of water, you have to be close.
  • California Sawyer
    • Madera Hardwoods
« Reply #38 on: December 14, 2017, 12:58:30 PM »
Gents, I noticed when the auxiliary fans are switched off that the WB temperature rises higher then when they are on. I forgot to switch the fans on last night, when I checked the kiln early this morning the WB had rises to 89, usually been sitting at 85ish. I may try power off the the auxiliary upper fans and just run a bank of three fans between the stack and L53 unit. Bumping the WB just a few degrees increased the humidity to 31% from 26%....
I should have the J2000 sometime next week.
-Marco
  • California Sawyer
    • Madera Hardwoods
« Reply #39 on: December 15, 2017, 09:38:02 PM »
UPDATE:
So after 24hrs with three box fans running behind stack and two auxiliary fans running no change in water removal rate. So I switched off the compressor, sealed the vents with hard insulation panels, and set the kiln to 150F.  I will let it sit till Sunday evening and check for moisture build up on the surface of the slabs.  Wish me luck.
New Nyle Kiln
Started by mer200pro on Drying and Processing
Last post July 07, 2005, 09:38:57 AM
by mer200pro
Nyle L 200 Kiln
Started by DennisC on Drying and Processing
Last post December 30, 2009, 08:13:36 PM
by ARKANSAWYER
Nyle Kiln
Started by chet on Wanted
Last post March 15, 2005, 04:33:25 PM
by raycon
Nyle L50 Kiln?
Started by WoodChucker on Sawmills and Milling
Last post September 04, 2003, 05:21:34 AM
by GarryW
