BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: What type of finish for a cremation urn?  (Read 923 times)
Online coalsmok
« on: November 15, 2017, 10:06:53 PM »
My wifeís mother passed away Monday.  Per her wishes her body was donated to science and we will be receiving her cremated remains after a few weeks.
 I volunteered to make a wooden box or urn to bury the ashes in after we get them back.  My choice of wood is either wild cherry or black walnut.  I prefer the cherry since it has been in the house for most of the year and is a little easier to work with and has a warmer color.
  My main question is what type of finish would last the longest within reason, not that I expect it to ever see the lights of day again but still want to put forth a good effort.  My first thought was a few coats of spar varnish on the outside and a coat of paint on the inside to help seal it up.  Epoxy may be a better choice but I have only used it once on wood and that was a coat of fiberglass resin to seal up a bee feeder that I made.
 Does anyone that has made one of these have any pointers?
Offline Savannahdan
  • Retired.
Re: What type of finish for a cremation urn?
« Reply #1 on: November 16, 2017, 04:35:01 PM »
This is something I plan to do with some of the wood I've cut and will be kiln drying.  Do a search and you can find the recommended dimensions of the urn needed for the size of person you will have ashes for.  I know of one fellow who did one and he used a jewelry box design but with access through the bottom.  I'm not sure if he sealed it with caulking/glue or just screwed the bottom in.  I tend to like a not so shiny finish on the boxes I do.  I've used Danish oil, spray lacquer and wipe-on poly.  Some folks like the high glossy look which if not done right can show a lot of sanding lines and sawdust left behind.  Look on Etsy and you'll find quite a few urns but be careful since some of them are for pets.  Our condolences on the passing of your Mother-In-Law.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline Downstream
« Reply #2 on: November 16, 2017, 11:39:09 PM »
Unfortunately, I have had experience with this type of project a few years ago when my brother unexpectedly passed away.  It was a tough but very rewarding effort and it made a big difference for everyone.  I made mine from cherry wood that I had sawed with my mill and air dried.  The finish I used was clear gloss poly over the natural cherry without any stain.  I also carved simple detail info on the top with my router and painted letters prior to finish.  The size was approx 18" x 10" x 10".  The bottom was removable with 4 screws so the mortician could put the ashes into it and then secure it in place.  I did not seal it.  Here is a photo of finished piece.  My mom has already requested I do one for her when needed.
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook
Offline sawguy21
« Reply #3 on: November 17, 2017, 01:36:54 AM »
A close friend did a beautiful urn for my mom. He used a dark stain that faded into light on the center of the top then painted a stain glass window on that portion. The effect is sunlight shining through. He finished it with a flat spray lacquer. My sister won't respond to requests to get it back for Karen's ashes but that's another story. >:(
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: November 17, 2017, 05:46:19 AM »
Did the same thing for my brother.
One on the right my brother on the left his daughter.
He had her in a box at his house, I put both in the ground in the family plot.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Online coalsmok
« Reply #5 on: November 17, 2017, 05:58:55 AM »
Thanks for the condolences.
 Downstream that is a very nice job.
The size of this one is not going to be standard as there are a few sentimental things that will be going in the urn with her ashes. I will take some pictures when I am done. Right now Iím waiting to see what all is going in the box.
Offline Bruno of NH
« Reply #6 on: November 18, 2017, 03:01:40 PM »
I have made many for my family and i use an oil finish on the wood ones.
Dad was a brick/block mason and would tell me growing up he wanted to be put in a brick up high and dry on a building.
I couldn't do that so i put him in a cement block with a Airforce emblem on it.
All his mason friends liked it :) :)
Made me fell good :)
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: November 19, 2017, 10:13:54 PM »
Here is the one that Bruno made/furnished for Andy White.
Offline AlaskaLes
  • Livin the dream!
« Reply #8 on: November 26, 2017, 07:10:59 PM »
We make quite a few of these for several local funeral services.
They come with either mitered corners or dovetailed corners and all get several coats of Sherwin Williams Sherwood Catalyzed Laquer I think it's "hand rubbed effect".
Dries very quickly and beautifully and we sand in between each double coat.
They get a good double coat inside and lightly sanded for an internal seal.
Ours generally end up in someone's house rather than buried.
You can see Mt McKinley from our backyard...Up Close!!
Mighty Mite MK 4B, full-hyd, diesel bandmill
Kubota 4wd 3650GST w/FEL; Forks;
3pt Log Arm& Log trailer
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
Robar RC-50 50BMG-just in case the trees get out of line
Online coalsmok
« Reply #9 on: December 06, 2017, 09:36:21 PM »
Still needs sanding and finish but here is the assembled urn
Offline Bruno of NH
« Reply #10 on: December 07, 2017, 06:48:39 PM »
Nice work
Online coalsmok
« Reply #11 on: December 10, 2017, 02:08:13 PM »
Here is the finished urn. Three coats of high gloss spar urethane. Made from black cherry a storm knocked down a few years back.
Offline AlaskaLes
  • Livin the dream!
« Reply #12 on: December 10, 2017, 02:42:53 PM »
Looks really good.
I like the grain in the top piece.
Husky 394XP
Husky 371XP
Husky 353
Echo 330T
Nyle 200M
Online coalsmok
« Reply #13 on: December 10, 2017, 08:04:56 PM »
Thanks for the compliments guys. Always thought that a burial is the last thing you get to do so it should be done as well as you can within their wishes.
That board had some nice grain in it. I cut the urn out of one board between the knots. It was close to the center of the tree so they were small.  If I were doing it again it would probably be linseed oil and beeswax finish.  Itís to hard to keep the dust out of the finish with a wood stove going in the next room of the the basement.
What type of finish for outside?
Started by rbhunter on General Woodworking
Last post May 08, 2009, 11:45:31 AM
by logwalker
Help - to determine finish type?
Started by Brad_bb on General Woodworking
Last post December 12, 2008, 12:07:32 PM
by logwalker
what type of finish on a table top
Started by Randy88 on General Woodworking
Last post February 06, 2016, 07:13:07 PM
by tule peak timber
Finish or not to finish bench for shower
Started by bucknwfl on General Woodworking
Last post March 23, 2016, 10:02:12 PM
by kderby
