Arborwear
Author Topic: Husqvarna 236 help wanted  (Read 462 times)
Offline Dionvh
« on: November 16, 2017, 12:29:04 PM »
Hi there,
I took my Husqvarna 236 to the shop because it wasn't running properly. They checked it and the piston was damaged. Repair would be 400 (some other things too), and seeing as a piston set was 30 online I decided to do it myself. No problem, piston was easy to install but now I have to reassemble the chainsaw. The shop took it apart and gave it back in pieces so I have no documentation of how it should be put back together. I'm putting back the carb but now there are two fuel lines coming from the body, and the carb has two point to which I can connect fuel lines. Now the bulb also has fuel lines connected to it? I cannot figure out or find a diagram of which fuel line goes where. Can anybody help me with this? I have a picture but for some reason I cannot upload it.
Thanks!
Offline dougand3
Re: Husqvarna 236 help wanted
« Reply #1 on: November 16, 2017, 03:25:07 PM »
Should be like a Poulan.
Fuel Pickup-line through hole under carb to carb nipple nearest to fuel pump side (1 big screw)
Other carb nipple-line to SHORT purge nipple.
LONG purge nipple line to tank hole in corner near clutch.
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
Offline Dionvh
« Reply #2 on: November 17, 2017, 09:38:49 AM »
So if I understand correctly, there's 3 fuel lines?
Offline LeeB
« Reply #3 on: November 17, 2017, 09:58:32 AM »
You can find the manual here but you might need to put in a some more info than just 236 to find it.
http://www.husqvarna.com/us/support/download-manuals/
Offline LeeB
« Reply #4 on: November 17, 2017, 10:05:09 AM »
I find manuals for a 235 but not a 236.
Offline dougand3
« Reply #5 on: November 17, 2017, 11:19:00 AM »
Yes, 3 fuel lines.
1. fuel supply - 10-12" long with fuel pickup in tank.
2. Short purge line from carb - 4-5"
3. Long purge line to tank - 7-8"
The purge circuit is to pull air out of carb to replace with fuel - supplied by the fuel supply line.
You don't NEED a purge circuit for a good running saw. It's a fairly new invention for cold starts requiring a few less pulls.
Poulan: 4218, 2000
Wanted: 50-56" bar for Husqvarna
Started by VPI on Wanted
Last post January 23, 2018, 10:39:17 AM
by VPI
Wanted husqvarna 61 white top cover
Started by symamania on Wanted
Last post June 29, 2015, 06:50:57 AM
by thecfarm
Scaffolding wanted - Jeff said it was ok to move to the wanted section
Started by kboilers on Wanted
Last post March 08, 2006, 09:08:20 AM
by thurlow
Husqvarna 285CD & Husqvarna 375K concrete saw
Started by Coach on For Sale
Last post June 25, 2014, 12:30:04 AM
by hacknchop
