Arborwear
Author Topic: firewood processor or not /  (Read 928 times)
Offline Coconut
  • Raised on saw dust
« on: November 16, 2017, 05:51:50 PM »
Hi everyone!   My question is this. If you produce 110 cubic cords of firewood a year is it worthwhile spending 30,ooo. dollars Canadian for a processor which is in very good shape ( circular ) ?   It produces 1 +  cords per hour. Please give me advice . Thank You  Coconut
Offline Hackermatack
Re: firewood processor or not /
« Reply #1 on: November 17, 2017, 07:39:18 AM »
I guess you need to do the math and figure out how many cords of profit will it take to pay for it and what the life expectancy and cost to operate the processer are. At my age and with the number of aches, pains and worn out joints I have it would be a easy call.
Jonsered 2230, 590, 70E. Kioti DK 35 /w fransguard winch. Hudson Oscar 236
Offline Grizzly
  • I wanna go camping!
« Reply #2 on: November 17, 2017, 11:04:34 AM »
I would also like to hear more on this. If that unit lasts 10 years (minimum I would think) you'll cut at least 1100 cord. So that make capital costs of $27.28 per cord. I don't know how much those outfits cost to operate so that needs to be added but for capital cost I'd sure like to buy one. All my sawmill waste could go through it as well.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
Cooks Cat Claw & Dual tooth setter
2000 Miners 3-31 Board Edger
Offline barbender
« Reply #3 on: November 17, 2017, 01:05:41 PM »
Coconut, you don't provide nearly enough numbers and info to go off of.
Offline Gearbox
« Reply #4 on: November 17, 2017, 05:22:31 PM »
From what I know you live in a small rual area . If you are doing 110 cord in  sales now go for it . If you are betting on the come for 110 cord I would think twice .
Offline hedgerow
« Reply #5 on: November 17, 2017, 06:12:13 PM »
If you are selling 110 cords of wood right now and the wood you are processing will go threw a processor you shouldn't have a problem paying for a $30,000 processor.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #6 on: November 17, 2017, 08:26:56 PM »
What would it cost to rent a processor in your area?
Would be worth considering since maintenance would would be on someone else...
Offline rjwoelk
    • countrysidefirewood
« Reply #7 on: November 17, 2017, 10:07:23 PM »
Check out Hakmet for a palax will do a cord a hr if you have a log deck. For 2/3 that price. Or a fully hyd for under 30.000.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline jmur1
  • Wood is King
« Reply #8 on: November 21, 2017, 12:44:12 PM »
Some of the not-so-obvious but significant factors are the following:
1.  Type of wood you process is a big factor including range of diameters and straightness of logs.  Does this machine handle your wood?
2.  Average temperature that you are processing in.  Make sure the cooling system can handle your area.
3.  Length of cuts - shorter cuts will raise overhead and increase time significantly.  Allow for the extra costs if you cut shorts.
4.  Mechanical aptitude and of the operator - training and understanding of the large forces at work can greatly reduce repair costs and machine damage.
5.  Basic math says 110 Cords @ 1 cord /hr will take 2.75 -  40 hour work weeks.  This means the processor will sit 11 months a year and if you don't store it inside it will rust and seize.  Or rent it out.
Easy does it
Offline Gearbox
« Reply #9 on: November 21, 2017, 05:48:34 PM »
I want one that will do 110 cord in 2 and 3/4 weeks . Mine will do a cord in 40 min. Why can't I do 10 cord in 8 or 9 hrs. OH I know you have to move the wood .
Offline starmac
« Reply #10 on: November 21, 2017, 10:05:34 PM »
What exactly is a cubic cord? Is that the standard 4X4X8 cord??
Offline barbender
« Reply #11 on: November 21, 2017, 10:36:12 PM »
Gearbox, the way I heard it with your's, the operator gives out and goes out for coffee after about 3 cords😊
Offline Grizzly
« Reply #12 on: November 22, 2017, 12:03:03 PM »
 :D :D :D
Offline Gearbox
« Reply #13 on: November 22, 2017, 07:32:19 PM »
Yes he does he is retired mabey retarded to .
Processor Build, Home Made Firewood Processor
Started by Higgo on Firewood and Wood Heating
Last post July 10, 2017, 06:57:27 AM
by Tony01
firewood processor
Started by woody1 on Sawmills and Milling
Last post September 05, 2007, 01:55:53 PM
by IL Bull
firewood processor
Started by J.J on Forestry and Logging
Last post February 27, 2006, 05:39:42 PM
by Ron Wenrich
Used Firewood Processor
Started by gypo1947 on Wanted
Last post February 10, 2013, 06:20:07 PM
by gypo1947
