BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Warrior 12” swing-blade  (Read 1164 times)
Offline NZJake
  • Board Moderator
    • 12 X 12 CUT MONO RAIL SWINGBLADE SAWMILL
« on: November 21, 2017, 02:00:38 PM »
Hi all, thought I’d share video footage of our new M12 Warrior model. Very happy with the result!
Wife says I woke up one morning half asleep uttering thin kerf and high production, I think I need a hobby other than milling?
Online Bruno of NH
Re: Warrior 12” swing-blade
« Reply #1 on: November 21, 2017, 02:14:41 PM »
Nice looking mill
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #2 on: November 21, 2017, 06:10:32 PM »
I really like what you have made with this series of mill Jake,
Question,  does the power plant and mill head separate
from the beam for alternative style transport and storage?
D
Offline NZJake
  • Board Moderator
« Reply #3 on: November 21, 2017, 06:45:49 PM »
Yes it can slide off the beam but you would need machinery to lift it off. The Auto range of mills are heavy. Carriage weighs around 150kg alone.
Offline Crossroads
  • let’s make some sawdust
« Reply #4 on: November 21, 2017, 07:46:13 PM »
Nice
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummings,
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« Reply #5 on: November 27, 2017, 03:53:37 AM »
Do you rate it as portable?  My 10 inch Peterson WPF is in my humble opinion barely portable.   And let me also add that it does not like the extra height of a Ford superduty 350 truck.  I have to use my aluminum trailer.
 All of the principal swing blade manufacturers offer videos with the saw head carriages being whisked around like little wheelbarrows.  I would say my 10 inch is more like a devils wheelbarrow, with a lead butt in the form of a very powerful but very heavy 35 hp engine.
Online thecfarm
« Reply #6 on: November 27, 2017, 07:49:40 AM »
I have never see one like that on a rail.
Offline NZJake
  • Board Moderator
« Reply #7 on: November 27, 2017, 01:26:41 PM »
I’d call our M6 and M8 portable. Our M10 and M12 a better term would be mobile. Takes around 15 minutes to lower the mill onto our trailer ready to roll out. Same attachment can be used for all models.
Offline starmac
« Reply #8 on: November 27, 2017, 02:27:24 PM »
I do not expect to ever own one, but am curious. What is the maximum size board you can cut with one?
Offline NZJake
  • Board Moderator
« Reply #9 on: November 27, 2017, 10:20:30 PM »
With this model you can cut 12” planks with ease (2 cuts).
You can cut slabs up to 24” wide by double cutting.
You can cut 61” slabs using the attachment slabber.
You can cut any width slab by flipping the log once.
Offline bandmiller2
« Reply #10 on: November 28, 2017, 07:58:50 AM »
Jake, tell us about the saw blade, do saw that size require tensioning. ?? Frank C.
Offline NZJake
  • Board Moderator
« Reply #11 on: November 28, 2017, 01:25:22 PM »
Hi Frank,
Yes these blades are pre-tensioned. We are using a special tooth design to mitigate resonance build up. Also using very narrow kerf with our machined Turbokerf design. It’s a six tooth to reduce bite impact. We’ve also tweaked hook angle to also reduce pull down.
Was very impressed with full 12” cuts without bounce in some rough looking poplar.
Offline drobertson
« Reply #12 on: November 28, 2017, 06:57:11 PM »
Nice vid  , its slow enough to see the action.
Offline MbfVA
« Reply #13 on: November 28, 2017, 07:49:35 PM »
Video's playing a trick on you.  It doesn't do enough fps to capture the motion in full.   Kind of like a strobe effect.   The blade is actually turning much faster than it appears to be.
Offline MbfVA
« Reply #14 on: November 28, 2017, 07:51:31 PM »
 Did you design this blade with replaceable teeth, bolt on?  I recall some discussion of that when you were putting forth info on the new thin kerf blade.
Offline NZJake
  • Board Moderator
« Reply #15 on: November 29, 2017, 12:51:22 AM »
I'm not really a fan of the insert teeth. Kerf is too fat and contrary to our companies direction. We offer them but always try and push the standard thinkerf TUrbokerf blades. They are old technology and ask a lot of your sawmill in the cut.
help needed for sawdust collection on a swing blade or a twin blade
Started by CaseyK on Sawmills and Milling
Last post November 11, 2015, 09:46:35 AM
by Ron Wenrich
Best Twin Blade or Swing Blade Tie mill layout?
Last post February 19, 2015, 11:25:31 PM
by Seaman
Swing blade arbor types Blade information
Started by kameljoe21 on Sawmills and Milling
Last post October 24, 2015, 08:23:11 PM
by kameljoe21
DIY Swing blade vs Twin blade sawmill
Started by nastcat on Sawmills and Milling
Last post March 26, 2014, 08:22:54 AM
by 5quarter
