Arborwear
Author Topic: fire chief FC 1700  (Read 420 times)
Offline OH logger
  • livin the dream
fire chief FC 1700
« on: November 22, 2017, 07:49:40 PM »
our local wood stove shop sells these add ons. I was thinkin of putting one in my 42'X80'X 17' tall fully concreted pole barn. the furnace would go in about the middle of the long wall.  it is insulated all around with 3" steel building style insulation with no ceiling but 3 ceiling fans. if I ran I a couple ducts to different areas of the building would it keep it around 50 degrees pretty consistently?? also if anyone has this model stove are they good quality and durable and dependable???  I know a ceiling would help but the fans should do something and they are already in place. I can load it when I leave in the morning and when I get back home from the woods (13 or hours).
john
Offline snowstorm
Re: fire chief FC 1700
« Reply #1 on: November 23, 2017, 06:15:45 AM »
i dont see how you could ever heat it without insulation in the ceiling. if it has a steel roof that will frost on the inside then drip when it warms up. what i used on my garage was 3" by 4x8 foam it has a fiberglass coating made by firestone. and screwed that to the trusses. when i built it 20 yrs ago no one said to put plastic under the steel. the condensation rotted some of the strapping. so this summer when i added on 20 ft we toke the old steel off and put plastic under that also
Offline OH logger
  • livin the dream
« Reply #2 on: November 23, 2017, 10:40:44 AM »
well the roof is insulated with the same insulation as the walls have. but I just don't have a  ceiling (at the bottom of the trusses) that's insulated. I should've been more clearer. does that change anything?? I would think it would. also our winters are not as bad as maine winters. we rarely get down to zero. 10 degrees is pretty darn cold here. right now I have one of those Val 6 (I think they are called) heaters. they run on diesel its basically a infared heater. if I leave it on overnight it will keep it around 40 in the morning. but it guzzles diesel. I'm just lookin for somethin made to run all the time and use wood (I have plenty around) and have a thrmostat
john
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #3 on: November 24, 2017, 10:34:34 AM »
Woodcutter_MO has one, but I don't know if its installed yet.
http://www.forestryforum.com/board/index.php/topic,98332.0.html
As for heating the building, it will depend on how air tight it is and how much/often you want to feed the stove.
Can you calculate the BTU output for your diesel heater?  This should give an idea what would be needed from a wood stove.
Offline OH logger
  • livin the dream
« Reply #4 on: November 24, 2017, 07:56:39 PM »
117,000 btus for the diesel heater and 170,000 for the wood furnace. I want to feed it in the morning when I go to the woods and not again till evening when I get home...if that's possible
john
Pulled the trigger on a Fire Chief outdoor furnace
Started by Woodcutter_Mo on Firewood and Wood Heating
Last post January 25, 2018, 05:29:03 PM
by dave_dj1
Chief Architect
Started by vtframer on Timber Framing/Log construction
Last post January 12, 2016, 03:58:59 PM
by vtframer
You're going to need a bigger mill chief......
Started by Delawhere Jack on Sawmills and Milling
Last post July 08, 2012, 08:30:22 PM
by backwoods sawyer
wink
Visit from my chief sawlog inspector.
Started by Danny_S on Sawmills and Milling
Last post May 02, 2004, 08:37:19 AM
by Danny_S
