Arborwear
Author Topic: MS380 power bogging down in top end  (Read 590 times)
Offline bandyfro
  • "The axe is calling my name again"
« on: November 27, 2017, 04:06:43 PM »
Hi friends, I'm a newby to the forum. I have an MS380. It was just serviced by the dealer but from the first time I used it after the service it has run really poorly. The problem is with the top end power, it bogs down and splutters terribly. Is it poorly tuned? If it is just the tuning then I can probably figure it out myself but otherwise I suppose I will have to take it back to the shop and spend even more $ on it. Thanks
The Axe
Offline limbwood
Re: MS380 power bogging down in top end
« Reply #1 on: November 27, 2017, 05:17:43 PM »
kinda sounds like it is running to rich on the high side.
Offline johnny newburgh
  • Teach the young bloods
« Reply #2 on: November 27, 2017, 08:09:45 PM »
If you just had it serviced I would bring it back and ask them check it out. If there was something wrong with saw from the beginning they should have told you it needed something? Maybe it is a little rich like Limbwood said but i would let them adjust it so they can set with tachometer good luck
Offline joe_indi
  • The older I get the more I learn
« Reply #3 on: December 11, 2017, 10:54:14 AM »
This has been a 'traditional' issue right from the 038 onwards.
The choke shutter is in the airfilter, held back by a small spring. In the process of cleaning, chances are the free end of the spring has come free of the groove, causing the shutter to be free of any resistance. When you rev at full throttle the vacuum  at the carb draws the shutter upwards to close the carb as in choke. Remove your hand from the throttle the choke shutter swings  back opening the carb again.
Solution: split the airfilter, position the choke shutter spring into its groove and close the air filter .
Offline 630red
« Reply #4 on: December 15, 2017, 05:57:15 PM »
check what Joe said,and make sure your fuel is fresh
Offline HolmenTree
« Reply #5 on: December 21, 2017, 12:35:32 AM »
The spring usually get stretched and weak with age.
Splitting the filter halves with a scrench so you can clean them easier sometimes can damage the shutter spring.
MS 310 Bogging, Not Full Power
Started by ms310 on Chainsaws
Last post December 28, 2015, 01:45:36 PM
by ms310
A Couple of Questions about a MS380 Stihl
Started by Rod Chambers on Chainsaws
Last post January 21, 2014, 08:49:15 AM
by Al_Smith
Stihl 046 bogging
Started by rangerbob on Chainsaws
Last post February 24, 2008, 09:49:02 PM
by Captain
how fast should it cut? bogging down : [
Started by flip on Sawmills and Milling
Last post August 29, 2005, 09:33:53 AM
by flip
