Arborwear
Author Topic: Modifing a cant hook  (Read 906 times)
Offline rjwoelk
    • countrysidefirewood
« on: November 28, 2017, 09:45:08 AM »
What are the rest of you folks doing to keep from putting holes in your cants with a cant hook? It has to grip. Had some success with just a board behind the ends but lots of time it slips. Perhaps modify the hook end with a steel 2x2 square that would have a rubber cap?
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Modifing a cant hook
« Reply #1 on: November 28, 2017, 05:27:49 PM »
   Sorry but that's how they're designed to work. If I am worrying about holes in the boards I hook it at the very end of the cant where any residual holes will likely get trimmed off anyway.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: November 28, 2017, 06:21:17 PM »
That's what I do, as well. It's not often with hydraulics, but sometimes I have to give an odd shaped cant a little help.
Offline John Mc
« Reply #3 on: November 29, 2017, 02:10:52 PM »
I wonder about making a replacement hook that has a flat metal pad with a few short spikes on it for grip. If the pad were mounted so that it could swivel to lay flat against the surface of the cant, it seems as though it might work. The several shorter spikes would give some grip, but the flat pad would spread the load and prevent them from penetrating very deeply.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #4 on: November 29, 2017, 03:52:28 PM »
you need a rubber band wrench. But in a 60" version with nylon strapping. :)
I knew what I thought I meant.
Offline Rooster
  • Tools are extensions of ourselves... share a tool.
    • Photobucket image storage account
« Reply #5 on: December 08, 2017, 02:52:42 AM »
This design uses hard rubber roller skate stoppers instead of points...
I have not made a prototype yet.
Peace, Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Offline rjwoelk
« Reply #6 on: December 11, 2017, 11:50:59 PM »
 Thanks to all the ideas.
Offline Don P
    • Calculator Index
« Reply #7 on: December 12, 2017, 08:50:00 AM »
Take a look at the pads on this grapple;
http://www.baileysonline.com/Forestry-Woodcutting/Skidding-Tongs-Brush-Grubbers/Brush-Grubbers/Heavy-Duty-Brush-Grubber.axd
I wonder if I could slip these onto someone's slasher without him knowing  :D
Offline John Mc
« Reply #8 on: December 12, 2017, 09:19:24 AM »
Those pads are like what I was picturing in reply #3, except I was thinking to add something to let them pivot a bit so they could lay flat against the cant. A ball & socket is one possibility, but I'm thinking it probably doesn't need to pivot left and right much, it just needs to go up and down a bit (I can't remember what you call the kind of joint I'm thinking about.)
Offline moodnacreek
  • Sawin by the notches
« Reply #9 on: December 14, 2017, 08:44:25 PM »
On a virgin cedar for natural edge, not banged up already, rare indeed, try to hook in the end trim area that is often cut off.
ethics of modifing someone's plan-advise?
Started by mikerat on Timber Framing/Log construction
Last post October 19, 2011, 05:22:54 PM
by mikerat
Name this hook
Started by r.man on General Board
Last post August 18, 2015, 07:19:56 AM
by thecfarm
Cant Hook
Started by Cory on Sawmills and Milling
Last post January 19, 2012, 08:42:42 PM
by WDH
my new log hook
Started by thedeeredude on Sawmills and Milling
Last post April 07, 2006, 06:48:15 PM
by thedeeredude
