Arborwear
Author Topic: Wooden Range Hood  (Read 899 times)
Offline FalconFan
Wooden Range Hood
« on: November 30, 2017, 08:58:46 AM »
We are doing a kitchen remodel and I was tasked with building a hood for our new range. I picked some poplar out of the stack that I cut from a tree that blew down at my granddad's house. The wood has some beautiful color and spalting. Lets begin!
Sawing the logs back in January.
Digging to the bottom of the stack to pick out the boards I want.
Measuring boards to see how much I needed.
Breaking down the stock and laying out the panels.
Using the thickness planer and a shelving board to flatten the boards. This was my first time doing this, it worked well (not perfect) and was pretty fast once I got the technique down.
I used hot glued on these pine blocks for clamping. I did this because I did not want to trim the ends of the boards before gluing them so that I could layout the panel to get the most color in it. One thing that I learned quickly was to NOT glue the blocks on parallel to the grain because it tore parts of the panel when I took them off. When I glued them perpendicular to the grain I did not have this issue. The hot glue held very well and made clamping a breeze.
I dont have many power tools at my house and did not want to make the trip to my granddads shop to work on it so I used mostly hand tools to cut and plane everything to size.
I also used my Stanley #45 to route out a groove that holds the plywood where the actual vent will mount in.
The compound angles were the most difficult part but having a sharp plane made it easier.
Here you can see the plywood inserted into the grooves and my makeshift bracing. I could not let my bracing interfere in the area where the vent will be.
Here is the hood after assembly and sanding.
And after the poly finish.
I still have to make the "chimney" portion to hide the duct that will go through the ceiling.
Offline samandothers
Re: Wooden Range Hood
« Reply #1 on: November 30, 2017, 10:39:18 AM »
Great work with the miter saw.  The final product look great!  Are there any code requirements related to how high the bottom needs to be above the cooktop?
Offline FalconFan
« Reply #2 on: November 30, 2017, 11:09:00 AM »
No code but the manufacturer of the vent recommends 26"-30" above the cooking surface.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #3 on: November 30, 2017, 11:10:46 AM »
Can't wait to see it in action!  8)
Offline 21incher
« Reply #4 on: November 30, 2017, 04:06:22 PM »
That is really nice. Will you line it with sheet metal to keep condensation from messing it up?  thumbs-up
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Chop Shop
« Reply #5 on: November 30, 2017, 06:45:35 PM »
It is a beautiful work  of art.
But isn't that a good way to start/spread a kitchen fire?
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #6 on: November 30, 2017, 08:02:58 PM »
You mean like cabinets, paneling or drapes might?
Offline WLC
« Reply #7 on: November 30, 2017, 08:07:43 PM »
WOW!!  Beautiful!  Looking forward to seeing the finished and installed version of this.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #8 on: November 30, 2017, 08:11:49 PM »
Beautiful !!!!Are you going to put a liner in it ? Nice work  8) 8) 8) 8)
   The liner will have the grease filters and blowers and be more fire resistant than bare wood. Cheers Rob
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
« Reply #9 on: December 01, 2017, 02:56:35 PM »
That's about the purdiest poplar I've ever seen, good job!
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline Bruno of NH
« Reply #10 on: December 02, 2017, 03:05:22 PM »
Nice work :)
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline FalconFan
« Reply #11 on: December 04, 2017, 08:26:42 AM »
Nice work :)
Thank you! It is very satisfying creating something from wood that you mill yourself. I bought the mill because I wanted to get into wood working but wood, with the exception of construction grade lumber, is so expensive!
I do plan on using flashing to line the bottom, around the fan to make it easier to clean and less of a fire hazard but like others have pointed out, it is not uncommon to have wood cabinets directly above a range. The main factor in preventing fires, in my mind, is staying on top of grease build up.
Wooden piston with wooden connecting rod
Started by hackberry jake on General Woodworking
Last post April 12, 2012, 01:23:38 AM
by Don_Papenburg
Hood s-182
Started by IMOWOOD on Forestry and Logging
Last post July 25, 2011, 03:02:38 PM
by IMOWOOD
Big Oak in the Hood
Started by UrbanLogger on General Board
Last post July 04, 2005, 03:45:28 PM
by SwampDonkey
Hood 7000.
Started by BargeMonkey on Forestry and Logging
Last post November 24, 2015, 10:30:12 PM
by BargeMonkey
