Arborwear
Author Topic: Pinless moisture meter for stickered lumber?  (Read 2516 times)
Offline scsmith42
    • Whispering Pines Farm
« on: December 03, 2017, 07:47:52 PM »
It's always a bit of a pain to find boards that can be slid out of the side of a stack for taking readings.  I recall that Wagner makes a remote sensor for one of their meters, but it's pretty pricy ($1,600).
Seems to me that I recall seeing a meter - maybe it was in an article in Sawmill and Woodlot - that was narrow enough to fit in-between stickered boards and it had an LCD readout on the side.  You could poke it a foot or so in between the boards and get easy readings from within the stack.
Can anybody advise me of the brand and potential source for this meter?  Any other alternatives other than placing remote probes in place as the lumber is stickered?
Thx.
Scott
Tom's 3638D Baker band mill
Offline GeneWengert-WoodDoc
Re: Pinless moisture meter for stickered lumber?
« Reply #1 on: December 03, 2017, 09:34:04 PM »
For most lumber, a side reading with 2 insulated needles driven at 1/4 of the thickness on the edge, will give you a very good estimate of the MC under 30% MC.
You could also get the remote jig from Delmhorst that allows you to insert their needles at two depths permanently (until done drying) and run wires which you attach to the meter.  Various versions can get fancy.
Offline Brian_Rhoad
« Reply #2 on: December 04, 2017, 12:08:22 AM »
Wagner makes a meter to check stickered lumber.
https://www.wagnermeters.com/shop/l722-stack-probe-sensor/
Which moisture meter do you use for rough sawn green lumber ?
Started by Dough_baker on Drying and Processing
Last post February 27, 2015, 11:37:13 AM
by Den Socling
question
Moisture Meter?
Started by CHARLIE on General Board
Last post January 28, 2002, 09:47:06 AM
by CHARLIE
Moisture meter
Started by rbarshaw on Drying and Processing
Last post August 16, 2004, 08:32:01 PM
by rbarshaw
Moisture Meter
Started by woodsdog2015 on Firewood and Wood Heating
Last post April 08, 2018, 04:11:14 PM
by woodsdog2015
