Author Topic: Classic issue  (Read 968 times)
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
Classic issue
« on: December 04, 2017, 08:51:49 AM »
My 4336 which is now 12 yrs old has an electronics issue.
I reduced the temp to max 150 for the summer for heating domestic h2o.
Now it wont let me increase the temp back to the winter heating temp i typically use.
Anyone out there have suggestions?
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Classic issue
« Reply #1 on: December 04, 2017, 12:04:13 PM »
I've had trouble resetting temps on my 6048 if I don't get the sequence just right.
Offline albirk
Re: Classic issue
« Reply #2 on: December 05, 2017, 05:28:13 AM »
You need a new temp controller. The new controllers when you get to 195 will go to 150  or 150 and then to 195. The old ones you could take up or down.
Re: Classic issue
« Reply #3 on: December 05, 2017, 08:43:48 AM »
Priced it out yesterday only 59or so  plus tax, not too bad.
One of the few things from central boiler thats not too pricey.
LT40SHDD51
Kubota 900 RTV
Offline albirk
Re: Classic issue
« Reply #4 on: December 06, 2017, 06:22:51 AM »
Make sure you turn the main breaker off. The rocker switch inside the door will leave one wire hot yet to the controller. That one wire will get your attention!!
Re: Classic issue
« Reply #5 on: December 06, 2017, 08:57:34 AM »
Thanks Al, I had planned on doing just that.
Looks like a fairly simple replacement
LT40SHDD51
Kubota 900 RTV
Offline Wood Shed
  • Retired antique tractor guy enjoying my Tree Farm
Re: Classic issue
« Reply #6 on: December 08, 2017, 04:31:01 PM »
pete,
Try to disassemble and clean connections to the controller and your ground.  Could save the cost of a new controller.  Had the same type problem with my 6048 a couple of years ago.
A society grows great when old men plant trees whose shade they know they shall never sit in. -Greek Proverb
Re: Classic issue
« Reply #7 on: December 09, 2017, 07:59:18 AM »
Havent got too far into the replacement so far just took the cover off and looked things over.
Everything looks good and clean in there by casual observation.
I will check connections but will probably replace anyway.
LT40SHDD51
Kubota 900 RTV
Offline albirk
Re: Classic issue
« Reply #8 on: December 18, 2017, 08:07:59 AM »
Pete did you get the controller replaced yet? Hope everything is working again.
Re: Classic issue
« Reply #9 on: December 18, 2017, 11:06:10 AM »
Yes al, week and a half  ago and it was a simple change out and works just fine
Bet I saved myself at least a 100 dollar service call plus the part.
LT40SHDD51
Kubota 900 RTV
E-Classic Issue
Started by Cass007 on Firewood and Wood Heating
Last post March 02, 2015, 05:51:43 PM
by garret
E Classic 2400 air flow issue?
Started by VTwoodburning on Firewood and Wood Heating
Last post November 17, 2014, 01:50:45 PM
by VTwoodburning
E-Classic 2400 Issue Revisitied
Last post March 16, 2015, 08:26:14 PM
by garret
E-Classic Re-lighting issue solved
Started by antos_ketcham on Firewood and Wood Heating
Last post August 22, 2008, 04:30:38 PM
by antos_ketcham
