Arborwear
Author Topic: Stihl 260 Pro & 391 issues after rebuild...  (Read 434 times)
Offline jiggysmb
  • Love Cuttin'
« on: December 04, 2017, 01:24:15 PM »
Figured I would condense these. I have rebuilt about a dozen Stihls due to scored pistons, leaking crank seals, etc, so I have some background. I was recently given 2 saws and here are their stories.
Stihl 260 Pro -low compression and broken handle but started and ran ok. I replaced the cylinder/piston, gas line/filter, rebuilt the carb and used an after market (chinese) fuel tank/handle. The carb on this saw was a little different than most. Fixed High screw on carb, and metering diaphram had a little nub to hit the needle lever. This area I was unsure of, with the lever sitting down in a sump, should the lever sit flush with the lip around that area? Either way, the saw wont start unless I dump some fuel mix in the carb and it will run for a couple seconds. Wont start at all pulling. I thought it was a fuel line issue, so I replaced the Chinese fuel line with a stock line and still wont start. Impulse line also came on the handle housing but fits tight. I wasnt sure where the Low screw on the carb should be so I tried 1/4 turn and full turn out with no luck. Any idea where the carb with no H screw should be set on the L side?
Stihl 391 - This saw overheated and needed a complete rebuild. It was a construction company's demolition saw, I dont know how it ran, it only had 2 loose screws holding the cylinder on. It would run for a second then cut out, and had 120 psi. Needed cylinder/piston/seals, fuel line, clutch, sprocket, carb kit, oil pump/worm. The saw will consistently start (150psi) but will only run at low RPMs with throttle held in, as soon as it is released saws cuts off. I am pretty meticulous about keeping parts together, but looking at some pics on ebay I see the carb has a black ring on one side? Mine does not have this. Also, I used the carb turns 1 L & 3/4 H  that are listed on the filter cover, but it seems like a carb issue, so I tried one off a working 391 and the saw acted the same exact way. Any ideas?
Offline dougand3
Re: Stihl 260 Pro & 391 issues after rebuild...
« Reply #1 on: December 04, 2017, 10:30:55 PM »
260 - I'd try a fully adjustable Walbro clone for ~$10.
391 - Muffler/Screen is clear? Try real rich - 2.5 L  &  2 H and see if can get a throttle up.
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
Offline jiggysmb
  • Love Cuttin'
« Reply #2 on: December 05, 2017, 07:26:31 AM »
Thanks Dougand3, carb ordered and I will let you know how 2 turns out works on the 391!
Offline jiggysmb
  • Love Cuttin'
« Reply #3 on: December 05, 2017, 07:03:30 PM »
Unfortunately 2.5/2 turns out just made fuel come out the exhaust.
Offline dougand3
« Reply #4 on: December 05, 2017, 09:42:44 PM »
If another known good 391 carb did not allow throttle up - the answer lies elsewhere. Easy start, good idle and boggy/no throttle up is a classic clogged exhaust symptom.
If the known good carb is a red herring - could be needle lever is too high = floody condition even on lean H-L screws.
Poulan: 4218, 2000
Stihl 036 Top End Rebuild
Started by Russ Prior on Chainsaws
Last post October 29, 2015, 07:42:43 PM
by Tom King
Rebuild stihl 011 avt
Started by Canadiana on Chainsaws
Last post May 07, 2016, 02:50:55 AM
by Canadiana
stihl 028 rebuild
Started by KahNon on Chainsaws
Last post November 13, 2014, 02:00:39 PM
by KahNon
460 Stihl Rebuild
Started by Ozark Cheapskate Logger on Chainsaws
Last post August 10, 2014, 01:32:11 PM
by OneWithWood
