Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: Considering OWB  (Read 685 times)
Offline swking
  • Member*
Considering OWB
« on: December 08, 2017, 09:22:14 PM »
First off thanks for allowing me to join such a great group.
I am planning on buying a boiler to heat my water and house with within the next 6 months or so. I am considering a Hardy OWB and or Central Boiler Classic Edge. Was wondering any pros or cons of either unit?
Thanks alot.
Offline armechanic
Re: Considering OWB
« Reply #1 on: December 09, 2017, 10:30:52 AM »
I have a Hardy installed in 2005, I have replaced the draft blower and this year I replaced the circulator pump.  Both rather cheap fixes.  The Hardy pumps are high, I got one from a local Hardware store about 1/3 the price. So yeah I would recommend Hardy.  One other bit of advice, get one size bigger than you think you need.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline armechanic
Re: Considering OWB
« Reply #2 on: December 09, 2017, 10:32:52 AM »
Almost forgot,  WELCOME to the board, lots of good advice.
Offline DDW_OR
Re: Considering OWB
« Reply #3 on: December 09, 2017, 01:21:08 PM »
here is a link to my Edge 750. so far i am very happy with it
http://www.forestryforum.com/board/index.php/topic,92218.0/all.html#top
...........One other bit of advice, get one size bigger than you think you need.
I agree, bigger is better.
the 750 will be used to heat the house, greenhouse and Hot tub. maybe a kiln?
it has connections for 3 loops
Harbor Freight Greenhouse build
http://www.forestryforum.com/board/index.php?topic=97497.msg1504967;topicseen#top
TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Multitek 1610EZ
Offline E Yoder
  • Heating with a HeatMaster GS100
Re: Considering OWB
« Reply #4 on: December 09, 2017, 02:14:15 PM »
Is the Hardy a KB downdraft unit or the updraft grated unit? The Edge unit and the KB Hardy are comparable units.
Downdrafters are considerably more efficient. I love my G100s and would have a hard time going updraft again after seeing the difference.
HeatMaster dealer support in VA.
GS100.
Offline mf40diesel
Re: Considering OWB
« Reply #5 on: December 17, 2017, 12:27:01 PM »
Iíll second the downdraft comment. We have a Heatmaster g200. We heat more area by quite a bit than all my buddies and use a little less wood plus itís clean as a whistle.
The emissions, even if you donít care (not assuming you donít) in the coming years could surely become an issue. Might be worth getting a compliant boiler now even if itís not yet required where you live.
John Deere 5055e, mfwd. Farmi JL306 Winch. Timberjack 225 Skidder. Splitfire splitter & Stihl saws.
