Arborwear
Author Topic: Solar kiln temps  (Read 323 times)
Offline vfauto
  • TimberKing 2000
Solar kiln temps
« on: December 11, 2017, 07:57:43 PM »
What is the hottest the solar kiln will reach?
The definition of insanity is to do the same things over and over and expect a different result!
Offline pineywoods
Re: Solar kiln temps
« Reply #1 on: December 11, 2017, 08:14:34 PM »
Don't really know, but I have documented 180 deg F in mine. Used a chart recording thermometer. Be advised, my kiln is a bit different from most, and I do live in the deep south...I normally see 40 deg over ambient, even on cloudy days...
Offline GeneWengert-WoodDoc
« Reply #2 on: December 12, 2017, 12:56:55 AM »
If the wood is fairly wet, then the extra heat will be used for evaporating water.  So, a solar kiln will run maybe only 10-20 F hotter than outside.  This is good, as the energy is being used for drying.
If the wood is dry, the extra heat will not evaporate moisture as easily so the kiln temperature will reach 30-40 F above outside.  Any hotter means that solar input and the heat created is not being efficiently used for drying.  Probably there is a relative humidity issue, as with heat and low RH the woood has to dry.  Maybe, the vents are not open enough.
Solar Kiln Temps
Started by GF on Drying and Processing
Last post December 09, 2004, 05:30:00 PM
by cozynest
winter temps and a solar kiln
Started by Tom L on Drying and Processing
Last post March 08, 2014, 03:16:04 PM
by GeneWengert-WoodDoc
Converting kiln schedules to lower temps?
Started by FeltzE on Drying and Processing
Last post July 10, 2013, 07:27:24 AM
by FeltzE
Mental Exercise! Hybrid kiln design (solar drying concept w/o solar heat)
Started by scsmith42 on Drying and Processing
Last post March 31, 2016, 10:51:46 PM
