Arborwear
Author Topic: Hackberry sawing  (Read 1263 times)
Online Southside logger
  • Sawing so I can afford to farm.
Hackberry sawing
« on: December 14, 2017, 12:46:32 PM »
Anyone ever saw or more importantly sell any hackberry?  What is it like?  Any advantage to QS?  I have a chance to pick up a pair of 30" ish hackberry logs if I want them.  Nice and clear on the sides I could see and the grain looks pretty tight.  One did have a decent check on one side but they are pretty fresh cut.  No visible stain or other issues.  They looked interesting to me, just not sure what to do with it, so input is appreciated.
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
Re: Hackberry sawing
« Reply #1 on: December 14, 2017, 04:05:44 PM »
Just beware of tramp metal.  Most of the hackberry I see in Central VA is growing around old house sites.  I've never sawed any.
Wudman
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: December 14, 2017, 04:56:07 PM »
It is in the elm family.  It has spiral grain like elm, sweetgum, and sycamore.  Flatsawn boards tend to warp and twist.  You could loose up to 40% of the boards because of this.  If you can quartersaw them, the boards will stay much flatter and your yield will increase significantly.  If you do quartersaw them, saw them 1 3/16" thick off the sawmill.
Offline D6c
« Reply #3 on: December 14, 2017, 06:01:29 PM »
I sawed a couple of smaller logs the other day.  White wood with dark streaks.  I just flat sawed it but the few pieces that came out quarter sawed had what I thought was a more attractive grain.  The plain sawed boards weren't all that good looking in my opinion.  I cut some of it 5/4 x 5 1/2 and some 4/4 thinking I might use it for the lumber on a carry-all for the back of the tractor.  I don't know if it has any commercial value, other than perhaps pallet mat'l.
Offline woodman58
« Reply #4 on: December 14, 2017, 07:37:41 PM »
I cut 9 logs a few years ago. I set them in the woods for a year to spalt them. I wish I would have left them for 2 years. They only spalted half way thru the length. They dried well with little degrade. You can look in my gallery for pics. You will get better money if it is spalted.
i LOVE THE SMELL OF SAW DUST IN THE MORNING.
Timberking 2200
Offline paul case
  • Original wearer of the PCM.
« Reply #5 on: December 14, 2017, 08:59:03 PM »
I cut quite a bit of it from time to time but mainly goes into pallet material. I like to make my trailer cants from hackberry as it is tough and generally dries out real light for hardwood.
PC
pc
Offline killamplanes
  • one man band
« Reply #6 on: December 14, 2017, 10:14:39 PM »
X2 on pallet stock, we have better species for other uses..but the blade will glide right threw like sycamore
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
Offline ToddsPoint
  • Stockmaker and Carver
« Reply #7 on: December 15, 2017, 05:14:22 AM »
I recently salvaged a lot of walnut from a woods the pro loggers cut.  I was surprised they cut all the hackberry they could.  It must have some commercial use for them to take it.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Offline fishfighter
« Reply #8 on: December 15, 2017, 06:45:27 AM »
When I have my place select cut logging, sweet gum and hackberry, they just chip it up. Was told they sell it for OSB.
Offline WDH
« Reply #9 on: December 15, 2017, 07:21:09 AM »
You best quartersaw it  :)
Offline ButchC
« Reply #10 on: December 15, 2017, 07:23:16 AM »
I had a Hackberry log up on the mill last fall and one of the local Amish stopped by and asked what in the world I was going to do with it ???  I said I dont know? Barn boards?  He pointed over to the outdoor wood burner and said Youll get much more worth out of it throwing it in that thing.
 I sawed  it up anyway, flat sawn,,  it will still burn.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline paul case
« Reply #11 on: December 15, 2017, 08:21:19 AM »
It is possible that some pallet makers search out hackberry just because it saws easy and nails good. The 3x4 market I have likes sycamore because they bore a 1.5''x2'' hole down in some pieces to hide the end of a bolt and the nut. Sycamore bores easy.
I bet that white wood looks good on pallets.
PC
pc
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: December 15, 2017, 08:35:04 AM »
This was for hobby/craft use, but it is pretty,
Offline fishfighter
« Reply #13 on: December 15, 2017, 09:43:43 AM »
Did that split?
Only good thing about a hackberry is in the winter when one goes coon hunting. DanG coons stack up in the trees for the berries. ;D In my younger days of coon hunting, many times my dogs treed up to 12 coons in one hackberry tree. :o
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #14 on: December 15, 2017, 09:49:39 AM »
If I remember correctly, they were 2" for benches, etc.
« Reply #15 on: December 15, 2017, 10:10:48 AM »
Well, it's looking like this may become a "to be continued" thread in a year or so.  I am thinking maybe QS one now and set the other one in the spalt pile with a "Best after" cow tag on it.
Hot wife
Offline WDH
« Reply #16 on: December 15, 2017, 04:38:42 PM »
Customasawyer and I quartersawed this one a few weeks ago.
Had some spalt in it and the pretty brown streaks.
« Reply #17 on: December 15, 2017, 07:50:41 PM »
That is quite pretty.  Any idea how long she sat around?
Hot wife
Offline WDH
« Reply #18 on: December 16, 2017, 09:13:28 AM »
Probably at least 9 months, maybe a year.  It has fungal conks growing on it.
Offline upnut
  • Wood Tick
« Reply #19 on: December 19, 2017, 07:02:08 AM »
A logger friend of mine likes hackberry for trailer decking and loading planks, light and tough, and bends without snapping.
Scott B.
I did not fall, there was a GRAVITY SURGE!
Hackberry worth sawing?
Started by rfalk on Sawmills and Milling
Last post April 06, 2008, 10:25:12 PM
by WDH
Red Oak vs Hackberry?
Started by ReggieT on Firewood and Wood Heating
Last post March 07, 2018, 03:59:39 PM
by ReggieT
Is this a Hackberry?
Started by TKehl on Tree, Plant and Wood I.D.
Last post May 18, 2017, 08:39:19 AM
by Brad_bb
Hackberry
Started by Knute on Sawmills and Milling
Last post May 18, 2010, 12:38:04 PM
by OneWithWood
