Arborwear
Author Topic: planers?  (Read 835 times)
Offline starmac
planers?
« on: December 15, 2017, 02:07:44 PM »
If a guy is looking at older used smaller planers, what advantage does something like a 718 woodmaster have over an old belsaw?
Is the finished product the same quality out of either one?
Offline 21incher
Re: planers?
« Reply #1 on: December 15, 2017, 07:05:20 PM »
I bought a new belsaw in the early 80's and used it for 35 years with no problems. With sharp blades it left a great finish. It also made great moldings. If the motor did not finally let the smoke out, l would still be using it. I wanted to go a little wider so I replaced it, but could have gotten another 30 years out of it with a new motor.
A woodmaster 718 will give you the extra 6 inches that I would say is a big plus, and spiral heads are available for it. On the other hand 12 inch blades are very easy to sharpen. Also some belsaw parts can be hard to find now.  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline bigred1951
  • logging and sawmilling
Re: planers?
« Reply #2 on: December 15, 2017, 09:57:40 PM »
I always liked the old big green powermaster planers. We had one in wood shop back in high school. Worked great and loud. If you was by it you could feel the vibration in the concrete floor. Even if you was way down the hall you could hear it running especially if they put a thick piece through it.
Offline bigred1951
Re: planers?
« Reply #3 on: December 15, 2017, 10:00:53 PM »
I meant powermatic.
Offline Kcwoodbutcher
  • Startin' to get the hang of it
Re: planers?
« Reply #4 on: December 15, 2017, 10:47:09 PM »
One of the biggest advantages is the 718 has a variable speed drive. It comes in handy when you start to bog down on a heavy cut or cutting crazy grained wood. It also has a couple of more horsepower.
My job is to do everything nobody else felt like doing today
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
Re: planers?
« Reply #5 on: December 16, 2017, 08:27:20 AM »
I've got an old belsaw I bought late 70s, replaced all the sprockets chains etc.  Has been running strong ever since, changed motors twice. Tough machine.
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
Re: planers?
« Reply #6 on: December 18, 2017, 07:50:31 PM »
I own a 718 with the spiral head.    LOVE IT !!!
Probably the biggest advantage is the 718 is still in production, so parts and support are not a problem.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Larry
Re: planers?
« Reply #7 on: December 18, 2017, 09:01:28 PM »
The Belsaw Company is still kicking.  Not its formal self, but can supply parts to keep the planing machines going.  I used to have a herd of them for some reason.  Most common wear part is the in feed rubber roller.
Larry
Nine out of ten trees recommend wood for your building project.
Offline Ed
Re: planers?
« Reply #8 on: December 24, 2017, 11:42:11 PM »
Woodmaster planers are basically a modern version of the old Bellsaw.
Ed
Planers
Started by JBS 181 on Drying and Processing
Last post June 14, 2009, 02:22:14 PM
by StorminN
planers and jointers
Started by Dan_Shade on General Woodworking
Last post February 16, 2007, 06:48:08 PM
by ksu_chainsaw
moved
MOVED: Planers
Started by Jeff on Sawmills and Milling
Last post June 13, 2009, 09:53:16 PM
by Jeff
portable planers
Started by turningfool on General Woodworking
Last post March 07, 2009, 12:21:22 PM
by turningfool
