KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Slab pallet  (Read 2697 times)
Offline DMcCoy
Slab pallet
« on: December 16, 2017, 02:23:07 PM »
Slab pallet.  Slabs are and have been a pita.  I divide mine into stuff to burn as scrap and firewood.  I wanted something that was simple, cheap, quick to build, durable, and repairable.  I also wanted a pallet that I could unload with forks ->a pallet I could carry with forks, set down, and then unload with forks in the case of the scrap to burn.
So here is what I came up.  I used;
1- 8' PT 4x4 post, cut into 3- 32" pcs.(skids and center support under slabs)
3- 5' 2x4( 2-5' pcs (edges)+ 1- 56" pc.(middle)
4- 4' 2x4 ( vertical stakes)
2- 32" 2x4 (edge support between vertical stakes under slabs)
2- 36" x 1/2" all thread with flat washers and nuts.
It measures 35" deep x 60" wide x 48" tall with vertical usable space of 39 1/2".  I don't know if the 2x4 on edge like that for the vertical stakes will be strong enough, I guess I will find out.
Pictures;
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Slab pallet
« Reply #1 on: December 16, 2017, 02:44:22 PM »
   Pretty neat. I may try building a scaled down version since my forks attach to my bucket and are only about 20" long and my FEL is on a little JD750. May make it about 2' wide and 3' tall or such.
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
Re: Slab pallet
« Reply #2 on: December 16, 2017, 03:19:02 PM »
Long ago I learned to make my slab pallets no thicker than I can cut in a single pass with my chainsaw. It makes it a lot easier to get them to firewood length when needed. Either way it's nice to be able to neatly get the slabs out of the way.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Slab pallet
« Reply #3 on: December 16, 2017, 07:01:42 PM »
Made mine out of steel, Works well for me, Will hold a cord if the slabs are 8' long, If longer then that would be more wood.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Slab pallet
« Reply #4 on: December 16, 2017, 07:25:46 PM »
I have made a bunch of these.  We have broken many of them.  I will try and remember to get some pics of myn.  I might have another pic on my phone that has one of my slab racks in it.  Myn will make a cord one of them will make a very plump cord.  The biggest thing we have found with making the uprights last the longest is they need to be hardwood and they need to be recessed into the wood that holds them.  So like we hse 2x6s fir the uprights and so we cut a 2x6 groove into the 6x6 it is screwed into.  They are easy to replace when they snap, just unscrew the 6 screws and pry out the broken stuff and slide a new one in and screw fast.  I put a little outward angle on the uprights so that the pack comes out easier.
Boy, back in my day..
    • A&P Saw mill LLC
Re: Slab pallet
« Reply #5 on: December 16, 2017, 09:13:18 PM »
With steel you build it once 4x4,  ;D ;)
Sawing since 1987
Offline 4x4American
    • Website Link
Re: Slab pallet
« Reply #6 on: December 16, 2017, 09:19:29 PM »
Well see heres the thing now Pete, Ive about got a phd with what I need for building slabracks.  I know just what size works and what dont.  So, yah pretty soon here Im gonna be fabricobbling a slab rack and a tie stacking rack too.  Its been so hectic lately getting everything ready for winter i aint had much time for much.  Friends always wanna do stuff Im like yah if I have any free time Im sharpening blades have fun tho lol
Re: Slab pallet
« Reply #7 on: December 16, 2017, 09:23:28 PM »
Peter,
   Absolutely right but some of us don't weld and we have an endless supply of wood. ;) Also my little JD would hardly be able to lift the pallet empty let alone full. I know I am under equipped with MHE but that is what I could afford at the time and will upgrade when I win the lottery or otherwise have excess funds available.
   One other addition I could see and will try would/will be to add ropes over the top of the uprights to reinforce and help keep them from spreading at the top during transport. I could see in my case making several narrow racks that my equipment can move and staging them side by side next to the mill and filling several at a time before moving them.
    • A&P Saw mill LLC
Re: Slab pallet
« Reply #8 on: December 16, 2017, 09:41:47 PM »
I made it with junk steel I had around,
I know 4x4 about the blade thing, I have boxes and boxes out in the barn to do. ::) :D
Sawing since 1987
Offline 4x4American
    • Website Link
Re: Slab pallet
« Reply #9 on: December 17, 2017, 12:10:36 AM »
I forgot to mention that I have a phd on them because of building them out of wood theyve broken so much that we learn alot about what they need to survive the harsh life of a slabrack...I will build a couple skookum steel ones when i can
Offline PA_Walnut
Re: Slab pallet
« Reply #10 on: December 17, 2017, 05:39:41 AM »
Peter, I think you are becoming a new hero to me!  :D
I need one like that! We have built several versions with scraps and even sawed some black oak specific for it, but they just don't hold up.
Been looking for a good reason to get a new MIG, and I assume the bugs don't like the metal so much,  so this might be it!  8)
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
Re: Slab pallet
« Reply #11 on: December 17, 2017, 07:47:45 AM »
   Here's another one, made from old pipe. On pipe skids so it's easy to move. Made 3' wide so my big saw will slice through in one pass.
  Ended up cutting the pipes off on one side and put sleeves in them so they are removable. Now it's a breeze to load and unload, started using it fo a firewood rack too.
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline DMcCoy
Re: Slab pallet
« Reply #12 on: December 17, 2017, 07:55:26 AM »
Ok, I have slab rack envy.
Looks like I need a bander now- feeling like a tool-aholic.   ::)
Offline Resonator
  • Board Footage and Cord Woodage
Re: Slab pallet
« Reply #13 on: December 17, 2017, 02:28:12 PM »
I built a firewood rack very similar to what 69bronco made. With the only addition being straps/bungees from side to side across the top of the pile, to secure all the pieces down when the saw bites in. I also spaced the stakes 16" apart as a guide for cutting 16" face cord wood.
Card carrying Wood-Mizer owner - 2017 LT28G19
Kubota MX5800 4WD HST, '07 Dodge Ram 2500 4WD 5.7 Hemi with 8'-2" Boss V-XT plow, a couple of Stihl chainsaws,
18 acres of trees, 7 guitars, and Class A CDL licence with about a million miles in a semi truck.
"Chasing the sawdust dream..."
Offline redprospector
Re: Slab pallet
« Reply #14 on: December 17, 2017, 06:14:37 PM »
A PhD?
Post hole digger?
Offline Resonator
Re: Slab pallet
« Reply #15 on: December 17, 2017, 07:04:07 PM »
No, his slabwood is Piled High Deeper[./u]      :)
Offline peterpaul
Re: Slab pallet
« Reply #16 on: December 17, 2017, 07:28:25 PM »
On the far left of the photo you is a corner of my slab rack.
http://www.forestryforum.com/gallery/displayimage.php?album=lastup&cat=40548&pid=237809#top_display_media
It's very simple, (2) 4x6 x 4'lg.  I stood the 4x6 up and drilled a 2" hole in each end with 3' space between holes. I just put a 4' pipe in each hole.  I'm loading it now for the first time.  I'll strap the slabs before I remove them from between the pipes
Woodmizer LT15, Kubota 4330 GST, Wallenstein FX 85, Timberwolf TW6, homemade firewood conveyor
Offline jmouton
  • never enough time
    • Log-Gistics
Re: Slab pallet
« Reply #17 on: December 18, 2017, 10:14:40 PM »
i think i made it easier ,  i got a steel frame heavy duty hay wagon frame trailer and i load it with slab wood 16 ft long and 8 ft wide and about 5 to 6 ft high , i just roll it around the yard if it gets in my way, when it s full i take it about a mile down the road and  let the firewood guy buy it cheap and he brings it back when empty ,,, i still have to load the huge piles of slab wood that i have  before i got trailer ,    so we will see how this works ,  if it dont a match will do it for me,   slab wood  is a pain,,,
        jim
lt-25 woodmizer,25 hp kohler,hyd loading,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Slab pallet
« Reply #18 on: December 18, 2017, 10:43:56 PM »
Me thinks I'll make one like 69bronco's. I kinda like how easy it is to cut it to firewood length.
1992 LT40HD
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Slab pallet
« Reply #19 on: December 19, 2017, 07:47:27 AM »
I have been thinking about this for when I start sawing. Since I also have wood stove in the house the slab wood will be great for that. May never have to buy firewood again :)
I knew what I thought I meant.
Pallet parts>
Started by woodhick on Sawmills and Milling
Last post December 19, 2007, 08:29:57 AM
by bull
Pallet vs Sawlog
Started by Rob on Forestry and Logging
Last post August 12, 2003, 06:33:34 AM
by OneWithWood
Pallet log question
Started by Sean.Kolb on Forestry and Logging
Last post October 22, 2012, 08:30:51 AM
by Sean.Kolb
The Wooden Pallet
Started by Ron Scott on Forest Education
Last post June 26, 2014, 08:21:45 PM
by jamesamd
